Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-21-2017, 03:11 PM
  #871
CaribbeanPirate's Avatar
I soooooooooooo want this !!! Got a reds 6.5T ready to pop in!
disaster999 and Ggrant like this.
CaribbeanPirate is offline
Old 09-21-2017, 09:10 PM
  #872
Regional Moderator
disaster999's Avatar
Ive always wondered why my belts are getting frayed. I thought its because I didnt trim enough of the servo ear and its rubbing against that when the car is running and the belt is jumping around. But while installing the upper deck, I noticed 2 screws have an excessive about of black dust on them. Upon closer look I realized the belts is actually rubbing against the screw heads. You can see the limited clearance the belt and the screw has
looking into either grinding down the screw head, or use set screws to limit the side to side movement when the chassis twists...
disaster999 is offline
Old 09-22-2017, 12:19 AM
  #873
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Looks like a good spot for countersunk flat heads.
liljohn1064 is offline
Old 09-22-2017, 02:18 AM
  #874
Regional Moderator
My thoughts at first, but was suggested that unless the counter sink holes are perfectly aligned, it will induce some tweak. how much of a difference would it make Im not sure but Im not too worried about it
I gotta find a way of countersinking CF without totally destroying my bit after 1 hole
Old 09-22-2017, 03:15 AM
  #875
Roelof's Avatar
There are also flathead screws.
liljohn1064 likes this.
Roelof is offline
Old 09-22-2017, 03:34 AM
  #876
True, just use countersunk washers.
Old 09-22-2017, 03:50 AM
  #877
MGU
MGU's Avatar
Just to make sure I got this right.
Flathead + countersunk washers so you do not have to chamfer (is this the correct english word?) the hole. Would not this be as high as the heads which are in right now?
and I doubt that you can fit two of these washers next to each other.
MGU is offline
Old 09-22-2017, 04:05 AM
  #878
Bar
Have you tried a different screw, some have flatter profiles, the Xray ones are quite low?
Bar is offline
Old 09-22-2017, 06:02 AM
  #879
Regional Moderator
Not yet, I'll check out my screw box this weekend and see if I could find something suitable
Bar likes this.
Old 09-22-2017, 06:36 AM
  #880
celt's Avatar
Perhaps this:
https://www.amainhobbies.com/schumac...hu4155/p248242
plus this:
https://www.amainhobbies.com/mugen-s...gb0740t/p18666
Will get rid of the crown of the fastener that is annoying your belts.
celt is online now
Old 09-22-2017, 07:34 AM
  #881
Roelof's Avatar
Roelof is offline
Old 09-22-2017, 09:33 AM
  #882
R/C Tech Elite Member
JayL's Avatar
https://www.amainhobbies.com/traxxas...tra3931/p17639
https://www.amainhobbies.com/axial-r...ia0109/p390279
https://www.amainhobbies.com/traxxas...tra3932/p17640
forFREEDOM likes this.
JayL is offline
Old 09-22-2017, 10:43 AM
  #883
Originally Posted by MGU View Post
Ok so I wonder how the two piece would work on carpet. I guess that's too much flex.
I assembled my MTC1 last week and tested on medium/high carpet track.
As some of you already mentioned, out of the box the car has too much flex.
It already flips over and had too much steering.
Anyhow, compared to T4'17 I drove the same lap time, even with that much flex.
Still waiting for the optional upper deck, and I hope that with the less flex, it's easier to drive with less steering.
In case some of you need that information:
Xray springs match and I assembled the progressive one 2.5-2.8 in front and 2.6 rear.
As I'm also waiting for Mugen's Anti Roll Bar and therefore I mounted them from Xray. They do not match 100%, but it's good working.
In case someone has already a hint to decrease the flex with the original upper deck, let me know. thanks
Freezer1980 is offline
Old 09-22-2017, 10:52 AM
  #884
I think the head on these screws will be too large in diameter... Can't be installed. I hear that Awesomatix upper deck screws might work though.
DavidNERODease is offline
Old 09-22-2017, 11:21 AM
  #885
snuvet75's Avatar
Trader Rating: 16 (94%+)
Or trim down the head with dremel might work.
snuvet75 is offline
