Mugen MTC1
#796
Actually the plastic counter sink washer that goes on the servo have a "locating pin" that fits into the hole of the servo ear so the servo doesn't slide around if you crash. You can use regular countersink washers and just crank down on the screw really hard but over time it will deform the plastic ears.
Get these if you want to upgrade them to aluminum.
https://www.rc-tworks.com/products/ta-031
#798
Strange that the gear chart doesn't indicate the max and min pinion for each spur - have to do math and stuff.
#799
Nah, no math (well addition), install a spur, any spur. Just keep adding pinions until you can't move the motor. Then remove pinions down until you lose good gear mesh. That number of teeth, no matter what ratio, will always be the most and least number of teeth for that pitch. Works for any car. From there you can tinker with moving the motor around with spur size to get that balance you are looking for knowing the pinion you have is big enough or small enough to still land in the middle of the range just by adding the two together. Once you get it figured out, make note. The gear chart comes in once you have the FDR you want then have to work the spur, pinion and motor location backwards to what gears you own. You'll quickly figure out the range of spurs to cover your possible FDRs and where it locates the motor at your desired ratio. The motor is a huge chunk of weight, so moving it around is more important than most people give thought to. They find something that fits and gear up or gear down. Moving 150g+ 10mm forward or backward can change everything. Back you your regularly scheduled program.
#801
Which one of these do you think is inaccessible to our friend?
Ain't that a bitch.
#804
Well you can only do that if you actually have the car. I had gear charts for my Durango and T4 where the possible gear charts were colored, so you could see what is possible before actually having the car. But thanks for the information, now I actually know that my planned spur/pinion combo will work.
#805
I think that one has been covered numerous times here, there are plenty of websites to do it for you or where you can find explanations, and I am pretty sure it was explained at some point in primary school.
Ain't that a bitch.
Ain't that a bitch.
#806
Car must be pretty good when the only complaints in a bunch of pages are about the Spur...
#807
Ain't that a bitch.
Ain't that a bitch.
I wish I was as smart as you think you are. Then I too could pat myself on the back for my useless rhetoric.
Go look at yourself in the mirror stewart smalley style. Cause you good enough, smart enough, and dog gone it people like you.
You obviously need the self esteem boost given the constant need to be a tool on this forum.
I hope you feel better. Internet hugs big boy. Internet hugs.
#808
Once again you are a real cool dude. Thanks for no value added commentary.
#809
#810
A MTC1 wiki would seem to be the solution to some of the... shall we say personality conflicts. This is a fantastic car and no doubt will continue to attract many questions.
