Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-15-2017, 10:12 AM
  #736
Here are my 2 MTC1's, definitely should not be compared to a Durango. After last week was able to Tq and win by a long shot. New track opened up, so get to test tomorrow. After the first run, can't wait to try some changes.
carkillaii, dawgmeat and Ggrant like this.
WEEZY is offline
Old 09-15-2017, 10:42 AM
  #737
OttoKrosse's Avatar
Car looked dialed last week, hope the changes slow you down a little. ...
j/k
OttoKrosse is offline
Old 09-15-2017, 04:08 PM
  #738
Trader Rating: 18 (100%+)
Any one had their MTC1 on carpet yet? Planning on running 17.5 with the Bitty m410 body, anysuggestions on setup from the get go?
Donkey is offline
Old 09-15-2017, 11:39 PM
  #739
MGU
MGU's Avatar
How did you attach the motor fan I cannot see it on the pictures.
MGU is offline
Old 09-16-2017, 03:09 AM
  #740
LOW ET's Avatar
Trader Rating: 103 (100%+)
i would guess servo tape???
LOW ET is offline
Old 09-16-2017, 04:24 AM
  #741
dan_vector's Avatar
Trader Rating: 27 (100%+)
So right ‘out of the box’ performance verdict is positive?
dan_vector is offline
Old 09-16-2017, 06:28 AM
  #742
OHBRAD's Avatar
Trader Rating: 19 (100%+)
Default awesome
Hi guys.
After having car built for 1 week, i finally got to test it..
Wow wow wow... i was very impressed..
Brad
Ggrant likes this.
OHBRAD is offline
Old 09-16-2017, 06:44 AM
  #743
Originally Posted by OHBRAD View Post
Hi guys.
Brad
What impressed u the most after the test bro ?
And how's the durability ?
Ggrant is offline
Old 09-16-2017, 07:01 AM
  #744
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Durability is not going to be an issue. Mugen has the best composite recipe in the business.
Ggrant likes this.
GrandeGixxer is offline
Old 09-16-2017, 12:14 PM
  #745
thisguy2849's Avatar
Hey Weezy can you tell me how the car compared in 17.5 to your previous car?
thisguy2849 is offline
Old 09-16-2017, 01:53 PM
  #746
Trader Rating: 65 (100%+)
How's it steer through the various parts of corners?
Antimullet is offline
Old 09-16-2017, 03:15 PM
  #747
MGU
MGU's Avatar
So apart from Axon spurs which others will fit?
MGU is offline
Old 09-16-2017, 06:35 PM
  #748
theproffesor's Avatar
Trader Rating: 63 (100%+)
With tires
snuvet75 likes this.
theproffesor is offline
Old 09-16-2017, 08:08 PM
  #749
lbckevin's Avatar
Trader Rating: 96 (99%+)
I had an xray spur gear in my box and it fits great.
lbckevin is offline
Old 09-16-2017, 10:53 PM
  #750
MGU
MGU's Avatar
The offset ones?
MGU is offline
