Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-11-2017, 12:51 PM
  #676
So do we want the motor to be positioned in the middle of it's adjustment range, or further back or further forward - from a weight distribution aspect?
DavidNERODease is offline
Old 09-11-2017, 12:57 PM
  #677
Tight indoor Ozite 17.5 in my case.
Old 09-11-2017, 02:30 PM
  #678
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I'm initially shooting for middle just to be able to go up or down based on temps. The 92 should put mine a little closer to the back.
liljohn1064 is offline
Old 09-12-2017, 06:07 AM
  #679
kentech's Avatar
Very extensive MTC1 build post now finished.
https://kentech.wordpress.com/2017/0...en-mtc1-build/
kentech is offline
Old 09-12-2017, 06:28 AM
  #680
Trader Rating: 65 (100%+)
Excellent work as always! I'm sold. .
Antimullet is offline
Old 09-12-2017, 07:47 AM
  #681
Bar
Fantastic build and review as always Kentech
Bar is offline
Old 09-12-2017, 08:14 AM
  #682
Several great build reviews of this car that seem to alleviate most concerns potential buyers might have. I should have mine from the LHS this Friday.
Old 09-12-2017, 10:57 AM
  #683
Default FDR
Originally Posted by liljohn1064 View Post
I have it implemented in my chart now. I have a 92 and 96 Axon Spurs and 39 to 48 pinions for our 21. 5 class on indoor carpet. Going to start with a 3.55 FDR, Motiv MC2 21.5, XR10 Pro stock spec and Bitty Nardo bodies. I'm going to run a 40mm fan right from the start. Kits arrive tomorrow.
Motiv says 3.9 to 4.1 FDR with a fan.
Old 09-12-2017, 11:20 AM
  #684
Cool, I'm there! Just pop in the 96 to start! Thanks David.
96/39 to 96/42, 43 puts it at 3.8. I do have pinions lower than 39, just not the nice Axon ones.
Old 09-12-2017, 11:40 AM
  #685
Those Axon spurs look really good so I'm gonna get a handful for my ever growing fleet - looks like they fit on everything which is awesome.
Old 09-12-2017, 11:49 AM
  #686
kentech's Avatar
Thanks guys. Happy if you enjoyed it.
Stein Tumert and Ggrant like this.
kentech is offline
Old 09-12-2017, 04:27 PM
  #687
Pretty neat what Mugen did with the servo mount I have to say... and the steering cranks and the front hubs and fug'n everything really. GIVE ME MY MUGEN!
Old 09-12-2017, 04:39 PM
  #688
Bar
Shared it on Mugen MTC-1 Facebook group as well
liljohn1064 and Antimullet like this.
Bar is offline
Old 09-12-2017, 05:24 PM
  #689
Dan
Dan's Avatar
Trader Rating: 66 (100%+)
Awesome coverage Kentech. Always enjoy your builds.
Dan is offline
Old 09-12-2017, 08:50 PM
  #690
team green's Avatar
Trader Rating: 14 (100%+)
Has anyone had problems with the belt tensioner rubbing on the spur gear? I had to remove it to get a 92 tooth to fit.
team green is offline
