Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-07-2017, 06:44 AM
  #586
Originally Posted by niznai View Post
what would you rather replace if you crash?
C blades on a driveshaft.
The plastic cups are fine when new, but spotting wear on them (well, in them) is harder - especially as installed.
cplus is offline
Old 09-07-2017, 06:58 AM
  #587
Bar
If anything like the Xray plastic spool cups then pretty rubbish.
Bar is offline
Old 09-07-2017, 07:26 AM
  #588
My VBC plastic spool cups are fantastic but I haven't run my Xray long enough to compare. Point being that plastic spool cups can be really good. I guess we'll find out soon enough about the Mugen's but I'm not worried.
DavidNERODease is offline
Old 09-07-2017, 08:12 AM
  #589
snuvet75's Avatar
Trader Rating: 16 (94%+)
But of course. That is exactly Xray style.
I think that should be a pretty durable setup and like I said, what would you rather replace if you crash?
Well, it is the matter of your preference. If you are worried about crash and incurred cost, you cannot use anything expensive in your car. In that sense, i think you are wrong. But as far as plastic outdrive is not as fragile as i think it would, i guess it is ok. And i didnt know xray uses plastic as well.
How is the wear on the cups compared with metal cups?
snuvet75 is offline
Old 09-07-2017, 08:31 AM
  #590
Bar
Wear on my steal outdrives with Orange blades is pretty much none existent after racing all year outside in 13.5 boosted, mod would be higher I imagine. The plastic standard ones wear quite quickly and have a lot of unwanted play after very little running.
Bar is offline
Old 09-07-2017, 09:15 AM
  #591
snuvet75's Avatar
I thought so. Unwanted play might be coming from the two sides of cup spreading out from each other like peeling a banana? LOL
Bar likes this.
snuvet75 is offline
Old 09-07-2017, 10:55 AM
  #592
cHckbOY5's Avatar
So is Hara a team driver for the MTC1 or just doing testing?
cHckbOY5 is offline
Old 09-07-2017, 11:09 AM
  #593
snuvet75's Avatar
But the MTC outdrives are closed ones I noticed. Aren't xray outdrives open? It looks like MTC outdrives may be able to prevent the play xray has provided that the inner surface of the plastic outdrives doesn't wear out too quickly.
snuvet75 is offline
Old 09-07-2017, 12:02 PM
  #594
daleburr's Avatar
Xray plastic outdrives are closed. They wear because the dshaft pin cuts into the plastic
daleburr is offline
Old 09-07-2017, 12:40 PM
  #595
RC MARKET's Avatar
New option parts
Attached Thumbnails Mugen MTC1-mu-a2127.jpg   Mugen MTC1-mu-a2405.jpg   Mugen MTC1-mu-a2809.jpg
RC MARKET is offline
Old 09-07-2017, 12:41 PM
  #596
RC MARKET's Avatar
Can use XRAY T4
liljohn1064 likes this.
Old 09-07-2017, 01:23 PM
  #597
border r/c's Avatar
Now ready for shipping
https://www.the-border.com/mugen-sei...car-a2001.html
border r/c is offline
Old 09-07-2017, 02:25 PM
  #598
snuvet75's Avatar
Then mugen should be similar to xray. Do xray guys change the cup to metal a lot then?
snuvet75 is offline
Old 09-07-2017, 03:56 PM
  #599
daleburr's Avatar
Yes. I'd get through 4 or 5 sets of the plastic ones in a season in 13.5 boosted. They're okay in blinky.
daleburr is offline
Old 09-07-2017, 07:57 PM
  #600
Regional Moderator
disaster999's Avatar
I could imagine the plastic outdrive wearing out a lot quicker than metal ones as well. And like others have said, the pin will dig into the plastic creating unwanted ware until it just free spins inside the cup from excessive ware. There is a reason why manufactures come out with metal replacements as an option. If you are going to talk cost, buying 4-5 pairs of plastic outdrive cups a season would definitely cost more than just a single set of metal one. Not to mention metal drive cups usually last at least 2 seasons. Also, think of all the time needed to break the car down to replace them if the plastic ones are worn. I rather deal with it one time than constantly wrenching on the car.
Im not even sure why so much emphasis is put on crashing. I have yet to break a metal outdrive cup yet, but if you manage to do so in a crash, you'll probably be dealing with far more than just a broken drive cup.
snuvet75 likes this.
disaster999 is offline
