Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-04-2017, 09:40 PM
  #541
Mitchy1986's Avatar
Superb quality
disaster999 likes this.
Mitchy1986 is offline
Old 09-04-2017, 10:00 PM
  #542
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by Mitchy1986 View Post
Superb quality
How do you know it is superb when you didn't even break the bags?
snuvet75 is offline
Old 09-05-2017, 12:47 AM
  #543
Started building my new buddy yesterday evening.
Coming from Awesomatix, I have to say the quality of all parts is very very nice with little details which make the car built up very easy.
Just for example all parts which are connected to the chassis (bulkheads etc.) are pinned which leads to zero misalignment. Bullet proof !!
Diff is note quite smooth yet, I guess I have to give it some run-in of course.
One thing which was not nice was the rear drive shaft. When screwing the little grub screw the inside sleeve is pulled towards one direction which results in a little overhang of the sleeve. Because of this it was not possible to fully rotate the drive shaft in all directions because the overhang of the sleeve was blocking it.
I tried different things but finally grinded down the sleeve one one direction (about 0,05mm). Now it is working.
However the drive shaft still feels not very smooth, I hope this improves during run-in...
Apart from that I had to ream the suspension parts a little bit (but no big deal). I also used aluminium shims instead of the plastic version. The suspension moves really smooth, with almost zero slop, no need to shim anything (don't know if it's different with plastic shims).
I hope to finish the rest of the kit today.. I still need to grind some more carbon parts.. but that is just for optical reason
cheers,
Felix
Benn0 is offline
Old 09-05-2017, 01:58 AM
  #544
update:
seems like I have mixed up the sleeves for drive shaft (black) and front steering (silver shiny)..although both have almost identical geometry it seems.. so probably unnecessary grinding of the sleeve ..
Will give it a new try this evening. Man that's stupid ^^
Benn0 is offline
Old 09-05-2017, 03:46 AM
  #545
gigaplex's Avatar
I've just been reading through the manual, and I didn't see any shock bladders. Are these emulsion shocks?
gigaplex is offline
Old 09-05-2017, 04:29 AM
  #546
Trader Rating: 18 (100%+)
Can anyone say if the body shares mounting location with either the Xray or Yokomo?
Pickthall likes this.
Donkey is offline
Old 09-05-2017, 06:50 AM
  #547
TomTurbo's Avatar
xray's won't fit
TomTurbo is offline
Old 09-05-2017, 08:31 AM
  #548
niznai's Avatar
Originally Posted by disaster999 View Post
locally, my LHS got them in stock and had him reserve one for me.
Does that shop have a website?
niznai is offline
Old 09-05-2017, 08:43 AM
  #549
Page 15. The part closest to the bottom left corner of the page is the bladder.
cyclonetog is offline
Old 09-05-2017, 12:16 PM
  #550
You are lucky your LHS actually carries relevant stuff than stocking the shelf with all RTR stuff like the ones here. I would so get this car if it wasn't for... on-road racing is dead here, no one cares, corrupt officials that misuses land, etc, etc Just gonna sit here and drool over the build pics...
redbones is offline
Old 09-05-2017, 01:29 PM
  #551
Mitchy1986's Avatar
cheers,
Felix
Oh dear....I don't think you read manual incorrectly bud. Mine are perfect! Really smooth and assembled perfectly
GrandeGixxer and Ggrant like this.
Old 09-05-2017, 03:38 PM
  #552
LOW ET's Avatar
Trader Rating: 103 (100%+)
in stock
https://www.amainhobbies.com/mugen-s...ga2001/p674922
el salvador likes this.
LOW ET is offline
Old 09-05-2017, 04:13 PM
  #553
gigaplex's Avatar
Right you are. Seems odd the way they tell you to install it, I can see air bubbles getting trapped.
gigaplex is offline
Old 09-05-2017, 07:26 PM
  #554
EDWARD2003's Avatar
Bee tops
Scroll down the page a little.
For those wanting close up shots of Hara's Mugen chassis.
EDWARD2003 is offline
Old 09-05-2017, 07:57 PM
  #555
about halfway finished mine. flawless build amd quality so far. only Issue I have/had is the spacers on the upper arm. will probably replace them with metal spacers instead. otherwise looking forward to running the car.
robbie_gtc is offline
