Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 07-01-2017, 08:27 AM
  #241
Dusttt's Avatar
Trader Rating: 126 (100%+)
I'm in! Love to see the old single car 1/10 bags come back too!
Dusttt is offline
Old 07-02-2017, 05:16 PM
  #242
Suspended
Trying to get all parts needed to get it running when it's available. What size turnbuckle wrench is needed?
Just ordered Bittydesign m410 body. Will be getting ride premounted tires, 28 red and 32 blue. Haven't done touring for three years. Been doing off-road. But I can't pass up a mugen tc, the only brand that can bring me back to this class.
Blaze85 is offline
Old 07-02-2017, 05:43 PM
  #243
Super Moderator
Marcos.J's Avatar
Trader Rating: 211 (100%+)
Originally Posted by latentspeed View Post
Really? Do you have to call people idiots? Just shows that you're a piece of shit hiding behind his computer. There's no need to declare it either, idiot. Don't ask for respect that you don't give.
Latentspeed since you made a second account during your suspension you just made your 10 day suspension a 30 day suspension make another account and it will be 1 year
Marcos.J is offline
Old 07-02-2017, 05:46 PM
  #244
Most likely 4mm turn buckle wrench.
Where are you going hitting a track? Indoor/Outdoor surface type? Ride 28 and 32s sound a bit too soft. Would check what the other folks in your area are running first
WagwanBumba is offline
Old 07-07-2017, 08:14 AM
  #245
I want my Mugen.
DavidNERODease is offline
Old 07-07-2017, 08:25 AM
  #246
Dusttt's Avatar
Originally Posted by DavidNERODease View Post
I want my Mugen.
Word!
Dusttt is offline
Old 07-07-2017, 10:27 AM
  #247
thisguy2849's Avatar
I want my Mugen.
Amen!
thisguy2849 is offline
Old 07-08-2017, 11:19 AM
  #248
niznai's Avatar
You have to love this guy.
The car is not even out yet, nobody's had one in front of them and this guy is worrying about the turnbuckle wrench.
niznai is offline
Old 07-08-2017, 12:35 PM
  #249
I have to confess that when I decided to get my VBC D06, I was concerned about the turnbuckle wrench too. I didn't want to scratch the sexy bits so I made sure I had the VBC graphite wrench set before I started the build. Later I found out that the Hudy wrench fits better on VBC than it does on Xray so I use that now - not a scratch on them and the little laser engraves (Robert Pietsch quote) are still perfect. LOL.
Old 07-08-2017, 12:43 PM
  #250
Speaking of cosmetics, my MTC1 is on order from the LHS and I'm actually worried it's going to make my brand new T4'17 look junky. The MTC1 has that military super high zoot look like the Awesomatix cars.
Old 07-08-2017, 05:31 PM
  #251
Have to say, gave me a bit of a chuckle.
cplus is offline
Old 07-08-2017, 05:44 PM
  #252
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Hopefully this one will work.
DavidNERODease and Antimullet like this.
Drift_Buggy is offline
Old 07-09-2017, 01:24 AM
  #253
Roelof's Avatar
Most Mugen default turnbuckles are like these"
Drift_Buggy likes this.
Roelof is offline
Old 07-09-2017, 07:53 AM
  #254
niznai's Avatar
Dang!
niznai is offline
Old 07-09-2017, 09:11 AM
  #255
Dusttt's Avatar
If you look at the pics it has both.
http://www.mugenracing.com/mtc-1/
Dusttt is offline
