Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 11-19-2019, 05:06 AM
  #1621
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
Carbon store custom, not available online. Special order.
DavidNERODease likes this.
1/8 IC Fan is offline
Old 11-20-2019, 06:02 AM
  #1622
hyperfuxx's Avatar
Trader Rating: 30 (97%+)
Is there a harder alternative to the stock steering blocks? For some reason on non hard hits I've broken 3 all of a sudden.
hyperfuxx is online now
Old 11-20-2019, 11:09 AM
  #1623
1/8 IC Fan's Avatar
Did they break at the steering arm / tie rod mount?
Old 11-20-2019, 12:04 PM
  #1624
SLOW 77's Avatar
Trader Rating: 30 (100%+)
I grind off the steering stopper that is on the gold caster block.. I found that this piece will hit in a wreck and snap the block, sometimes in a hard wreck it would break the stopper off the caster block even.
SLOW 77 is offline
Old 11-20-2019, 12:19 PM
  #1625
hyperfuxx's Avatar
Old 11-20-2019, 12:20 PM
  #1626
hyperfuxx's Avatar
And it’s the inside tire related the the wall surrounding the track. All 3 have been on this side.
Old 11-20-2019, 12:21 PM
  #1627
hyperfuxx's Avatar
Could you post a picture? Iím not understanding the gold caster block deal
Old 11-20-2019, 12:22 PM
  #1628
SLOW 77's Avatar
Nevermind, you are using the C-hub design, I was referencing the older style.
If those break, that is where mine usually break too, fyi. You running a solid arm, or a servo saver?
SLOW 77 is offline
Old 11-20-2019, 12:32 PM
  #1629
hyperfuxx's Avatar
I do not. I’m not sure that would save it considering I can slide a 3mm washer between the 2 at full swing with the radio on.
Old 11-20-2019, 12:45 PM
  #1630
1/8 IC Fan's Avatar
Hyperfuxx, i imagine your not running a servo saver. Curiosity is that i wonder, even with a tighter / stiffer servo Saver, if perhaps it will prevent this on your car? The only other thing, but not sure is if boiling the steering knuckles would render them more.pliable, lile we used to do on the MBX6-7? Has anyone played with Tamiya or Xray knuckles? Ill check the tamiya ones when i get home.
Old 11-20-2019, 09:43 PM
  #1631
Originally Posted by hyperfuxx View Post
And itís the inside tire related the the wall surrounding the track. All 3 have been on this side.
Make sure youíre running at least the 5.5m steering stop collar on the bottom side of the steering rack center block. I prefer 6.0m myself, but others on this thread like the 5.5m. Just something to double check. All 3 of my cars have taken serious hits and surprises me that the car is able to race on.
casrcr is offline
Old 11-21-2019, 04:04 AM
  #1632
hyperfuxx's Avatar
I do have the 6mm on. I’ll have to double check everything. I recently installed the performance kit and shortly there after this is when the problem started.
Old 11-21-2019, 04:43 AM
  #1633
hyperfuxx's Avatar
With the 6mm should the upright touch the C-hub with the car off? Doesn't seem the steering stop is doing its job. I have a 1 mm for bump steer and I never checked the toe after install. Maybe I have too much toe in?
Old 11-21-2019, 05:49 AM
  #1634
The arm on that knuckle is ridiculously thin for a high stress area. Look at almost every other manufacturer, that arm is 2 times as thick or made from a much stronger material (graphite or aluminum). It doesn't help they pocketed the arm and added a giant hole for the insert.
Can you fit knuckles from another brand on the car?
malkiy is offline
Old 11-21-2019, 06:09 AM
  #1635
hyperfuxx's Avatar
Does anybody know if the X-ray are compatible? I know the rear are an exact match
