Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 08-08-2019, 04:34 AM
  #1576
tom1974's Avatar
Where i can find belt low fiction?
tom1974 is offline
Old 08-08-2019, 05:00 AM
  #1577
Super Moderator
Marcos.J's Avatar
Trader Rating: 211 (100%+)
https://www.apexrc.com/products/xeno...white-belt-s3m
Marcos.J is offline
Old 08-08-2019, 07:10 AM
  #1578
Originally Posted by jay m View Post
What's people thought on chassis for black ETS carpet , will standard carbon work or is alloy the go? What alloy chassis is getting best results .
Depends on front layout.
With the old front upper arms, I think alloy frame (the Mugen one, not aftermarket products) is kind of mandatory on high grip surfaces.
With the performance kit, maybe you can try the carbon chassis.
jakelamotta is offline
Old 08-08-2019, 08:02 AM
  #1579
tom1974's Avatar
which cod number i put in my shopping cart for buy belt front and rear?
tom1974 is offline
Old 08-08-2019, 10:26 AM
  #1580
I purchased mine directly from Xenon. Part #'s 1- Bel-0180, 1- Bel-0507. 1 rear, and 1 front.
casrcr is offline
Old 08-18-2019, 10:20 AM
  #1581
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
Good.showing by Eric Dankel in Ettlingen
1/8 IC Fan is offline
Old 08-19-2019, 05:37 AM
  #1582
Can someone please confirm the correct thickness for shock 4 hole part? While building I discovered that 3 are 2 mm thick and 1 is 1.5mm thicknesss. 1.5 moves freely and 2mm is very tight.
rayrush is offline
Old 08-19-2019, 11:52 AM
  #1583
The thicker 3 are correct - the E-Clip is supposed to be recessed into the piston head.
DavidNERODease is offline
Old 08-20-2019, 07:39 AM
  #1584
Thanks David
rayrush is offline
Old 09-15-2019, 07:56 AM
  #1585
hyperfuxx's Avatar
Trader Rating: 30 (97%+)
Need advice. Ordering this kit next week and I never ran a on road car. HT is putting together a black carpet track and asking what I’m going to need as far as setup, tools and tires. Know I’m gonna need a ride height gauge but is that it as far as tools? I plan on running Hobbywing esc but a stock motor is open to what ever. 17.5 is stock, right? These guys run parking lot and now they’re coming indoor and I’m not sure what they now about carpet and I def know they never seen a Mugen TC before. What’s a good tire for black carpet? Thinking I’ll need spare arms and maybe body posts. Not looking for tons of hopups because I’m not sure how far I want to take this until I figure it out first. Maybe get a aluminum chassis later cuz I would think that would be better for high grip. I’ll go with a bittydesign body cuz I love their 1/8 buggy bodies.
hyperfuxx is offline
Old 09-15-2019, 08:11 AM
  #1586
Super Moderator
Marcos.J's Avatar
Originally Posted by hyperfuxx View Post
Need advice. Ordering this kit next week and I never ran a on road car. HT is putting together a black carpet track and asking what I知 going to need as far as setup, tools and tires. Know I知 gonna need a ride height gauge but is that it as far as tools? I plan on running Hobbywing esc but a stock motor is open to what ever. 17.5 is stock, right? These guys run parking lot and now they池e coming indoor and I知 not sure what they now about carpet and I def know they never seen a Mugen TC before. What痴 a good tire for black carpet? Thinking I値l need spare arms and maybe body posts. Not looking for tons of hopups because I知 not sure how far I want to take this until I figure it out first. Maybe get a aluminum chassis later cuz I would think that would be better for high grip. I値l go with a bittydesign body cuz I love their 1/8 buggy bodies.
if you want that car to work on Black carpet you are going to nees alot of hop ups, honestly is not the greatest car for black crc carpet , i had it ran it tried everything and it was not the greatest car.
racer034life and Ggrant like this.
Marcos.J is offline
Old 09-19-2019, 08:59 AM
  #1587
tom1974's Avatar
Hallo this is my question
I have put gear spur 90 t but the spur touch on the chassis is possible?which is the maximum spur I can put in my mtc1?
tom1974 is offline
Old 09-19-2019, 09:08 AM
  #1588
Mugen MTC1 - Gear Chart
Old 09-19-2019, 09:17 AM
  #1589
I have run a 90 spur on mine with no problem. Max is 116 spur
JerseyRC is offline
Old 09-20-2019, 12:12 AM
  #1590
tom1974's Avatar
90 with pich 48 ?
tom1974 is offline
Copyright ゥ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
