Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 06-03-2019, 09:58 AM
  #1531
tom1974's Avatar
Originally Posted by tom1974 View Post
Another question the new and option a2231 with joint pin are alluminum or steel?
can i use joint pin another chassis(xray....yokomo....etc)?
i can find joint pin delryn?
thanks
tom1974 is offline
Old 06-03-2019, 10:40 AM
  #1532
LOW ET's Avatar
Trader Rating: 103 (100%+)
scuse me....
motor 4.5t
spur gear 48p
88 tooth 48p
https://ultitires.com/index.php?rout...product_id=654
LOW ET is offline
Old 06-03-2019, 12:11 PM
  #1533
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
the blades go with the alum outdrives on the car. Stock in the rear, option part for the front. There is a steel front outdrives option, but I don't know if it works with the blades. As for other chassis manufacturers blades working in place of the Mugen ones, I'm not sure. I just use the Mugen ones. I'm not sure if anyone makes a delrin blade either.
Teufel Racing is offline
Old 06-03-2019, 12:57 PM
  #1534
tom1974's Avatar
if you buy a2231 i Think you have outdriver steel and joint pin.
tom1974 is offline
Old 06-03-2019, 12:59 PM
  #1535
tom1974's Avatar
Xray... kyosho buggy...
tetra
tom1974 is offline
Old 06-03-2019, 01:00 PM
  #1536
tom1974's Avatar
Originally Posted by LOW ET View Post
pinion?
19....20....22 ??
tom1974 is offline
Old 06-03-2019, 01:04 PM
  #1537
tom1974's Avatar
[QUOTE=tom1974;15459498]There is a steel front outdrives option, but I don't know if it works with the blades.
Steel bot used blade?
tom1974 is offline
  #1538
tom1974's Avatar
[QUOTE=tom1974;15459505]
Steel not use blade?
tom1974 is offline
Old 06-03-2019, 01:44 PM
  #1539
LOW ET's Avatar
pinion?
19....20....22 ??
i have a 20 tooth on mine.
LOW ET is offline
Old 06-11-2019, 08:31 AM
  #1540
tom1974's Avatar
This is my mtc1....i nave use esc and motor economic ...😀
tom1974 is offline
Old 06-13-2019, 03:32 PM
  #1541
tom1974's Avatar
Originally Posted by TryHard View Post
You can make your own... just grab some 3mm Aluminium standoffs (I use 15mm), and then mount them where the tape mount parts go on the brackets. Then use some small car5bon plates on top to act as the retainers.
I also space the L shape brackets up 2mm off the chassis, and then extra shims between post and bracket to get the correct battery float.
3mm Alu Standoffs
I have these on both my cars, so much easier than tape
have you photos please
tom1974 is offline
Old 06-27-2019, 12:28 PM
  #1542
LOW ET's Avatar
thoughts on these? has anyone had problems resulting in a need for them? https://www.redrc.net/2019/06/mugen-...r-arm-inserts/
LOW ET is offline
Old 06-27-2019, 12:32 PM
  #1543
Biz_Nessman's Avatar
I haven't noticed a need, but I can see how they may strengthen the mounting position and possibly make the suspension more consistent without the flex that may be there with the plastic inserts
Biz_Nessman is offline
Old 06-27-2019, 12:40 PM
  #1544
xpressracer's Avatar
It's about time, for me it was the weakest part when hitting the wall and screws loosening up, nowadays not hitting the wall as much so the plastic is holding up. I plan on grabbing these.
xpressracer is offline
Old 06-27-2019, 12:52 PM
  #1545
LOW ET's Avatar
thats what i was thinking.
LOW ET is offline
