Like Tree759Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 05-29-2019, 10:53 PM
  #1516
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Originally Posted by tom1974
which are the sprigs use?
Xray number....
smj number....
axon number....
Hard to say for sure, as it can be track dependent or grip dependent, and class dependent
Xray:
2.6, 2.7, 2.8, and 2.9 would be good to have on hand. If you want the progressive ones, the 2.3-2.6 and 2.5-2.8 are what xray has. I'm mostly around the 2.6 all around or 2.6 front and 2.7 rear at the moment, or that's what's currently on the cars anyway.
SMJ:
They are a bit cheaper to get and do now have some rates that are a lot closer to what xray has.
Red progressive front and blue rear was what I had ran last on those, and they were ok. I have ran the red progressive front and yellow progressive rear before and they were good in USGT, was going to try the yellow front and red rear setup, but didn't get around to it.
Axon:
i haven't ran this brand, but have looked at what they have, and they do seem to have a much finer set of spring rates from when compared to the other two.
for example they have 2.5, 2.6, 2.7, and such like Xray and now SMJ do, but Axon also has 2.55, 2.65, 2.75, and such that fall between the rates. Don't know if they're good or not, but I could see the finer rates being worth trying.
Teufel Racing is offline
Old 05-30-2019, 08:00 AM
  #1517
tom1974's Avatar
The rear spring smj blue is hard than yellow ?
tom1974 is offline
Old 05-30-2019, 09:51 AM
  #1518
tom1974's Avatar
The springs fronf and rear are simile?
tom1974 is offline
Old 05-30-2019, 10:10 AM
  #1519
tom1974's Avatar
Can you give me cod. number or link where I can buy spring smj red ....yellow....blue for mugen mtc1
the smj spring for mugen is short or long?
tom1974 is offline
Old 05-30-2019, 03:35 PM
  #1520
STLNLST's Avatar
Trader Rating: 32 (100%+)
https://ultitires.com/
this is where I get my springs from. Get the package springs rather than buy individually. I have bought duplicates of a couple just to run the same front and rear.
Moderators......wasnt sure if I could post the link I did. Just trying to answer a fellow racers question. If I’m punished for doing so I can accept it.
STLNLST is offline
Old 05-31-2019, 05:03 AM
  #1521
tom1974's Avatar
Thanks man..
but the springs i Buy are short or Long progressive for mtc1?
tom1974 is offline
Old 05-31-2019, 07:46 AM
  #1522
SLOW 77's Avatar
Trader Rating: 31 (100%+)
Short
SLOW 77 is offline
Old 06-01-2019, 03:23 AM
  #1523
tom1974's Avatar
Originally Posted by SLOW 77
Short
I am a beginner I have never had a 1/10 touring you have to excuse me if I ask. The blue springs smj 2.7 are not progressive?
tom1974 is offline
Old 06-01-2019, 08:27 AM
  #1524
STLNLST's Avatar
the blue springs are linear. The progressive spring will have two numbers associated with their ratings. 2.5-2.8 for example.
STLNLST is offline
Old 06-01-2019, 11:16 AM
  #1525
tom1974's Avatar
Thank you very much
tom1974 is offline
Old 06-02-2019, 08:37 AM
  #1526
tom1974's Avatar
Which spur gear can i use for my mtc1 mugen?
yokomo .....xray....Schumacher...etc
which are compatibile?
thanks
tom1974 is offline
Old 06-02-2019, 02:46 PM
  #1527
thanks
i know there's a few that fit. Axon TC spurs is wat I use and I think what a lot of racers use at the local on-road track.
There's a number of places on line that carries them. Amain and Ulti Tires are the two I have got all mine from
Old 06-02-2019, 02:49 PM
  #1528
thanks
what calass your running? Mod TC, the spur gear seems to be 110-114 I think, 17.5, likely 102-108 maybe, and 21.5/USGT 102-104. At least those are the general ranges I have or have run. All in 64p.
Old 06-03-2019, 09:51 AM
  #1529
tom1974's Avatar
scuse me....
motor 4.5t
spur gear 48p
tom1974 is offline
Old 06-03-2019, 09:57 AM
  #1530
tom1974's Avatar
6Another question the new and option a2231 with blade are alluminum or steel?
can i use blade another chassis(xray....yokomo....etc)?
i can find blade delryn?
thanks
tom1974 is offline
