Like Tree758Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 05-25-2019, 08:53 AM
  #1501
tom1974's Avatar
Hallo if I want use motor 5.5 or 4.5t which pinion and crown I use?
tom1974 is offline
Old 05-25-2019, 09:08 AM
  #1502
Probably 116tooth (64pitch) crown (spur) and 27tooth (64pitch) pinion but of course this depends on the track size. ESC programming, and many other factors.
DavidNERODease is offline
Old 05-26-2019, 03:37 AM
  #1503
tom1974's Avatar
Thanks the track is short.....smooth and use late tyres .the track is bitume liquid .
that should I have as spare parts ?
there are weak pieces or devices I need to do?
tom1974 is offline
Old 05-26-2019, 04:48 AM
  #1504
tom1974's Avatar
Dove posso trovare il numero di codice corona 95t ..99t or 100t (pich 64)?
With pich 64 can i use pinion 48dp?
quanti denti hanno la corona originale?
tom1974 is offline
Old 05-26-2019, 05:04 AM
  #1505
tom1974's Avatar
the smaller the number, the harder the spring?
tom1974 is offline
Old 05-27-2019, 09:42 AM
  #1506
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
general spares for the car are the usual stuff to have,
arms and steering knuckles, extra sway bars (at least the 1.3 rear), maybe a set of belts just in case.
not sure anything on the car is weak, but of you hit something hard enough, something will likely break. Depending on what car you have (old front end or the new performance upgrade kit A2002 for the car), will determine what option parts you may want. If still using the old style front end, then making sure you have the one piece top deck is a must. You can either use the first gen top deck, or you can use the new top deck that comes with the performance upgrade kit, if you want to use the new pitch rod setup with a slight mod to the top deck to fit the old style front end parts. If you already have the performance upgrade kit on the car, then you don't need much else in option parts, aside front some of the option wheel hexes and maybe a belt tensioner. You could also get the fan mount if you don't have that too.
Teufel Racing is offline
Old 05-27-2019, 09:45 AM
  #1507
if I understand your question correctly,
no you can't use 64 pitch with a 48 pitch gears. Have to be the same pitch for both the spur gear and pinion. I think most everyone uses 64 pitch in general
Old 05-27-2019, 09:48 AM
  #1508
smaller the number of the shock springs, the softer the spring rate.
STLNLST likes this.
Old 05-27-2019, 01:41 PM
  #1509
tom1974's Avatar
someone has a picture to see how the belt tensioner is mounted?
can i find this part aftmarket?
tom1974 is offline
Old 05-27-2019, 08:44 PM
  #1510
STLNLST's Avatar
Trader Rating: 29 (100%+)
I agree.....info was posted incorrectly by original poaster.
STLNLST is offline
Old 05-28-2019, 06:30 AM
  #1511
tom1974's Avatar
In the mugen buggy 1/8 if the number is big ....the spring is soft.
tom1974 is offline
Old 05-28-2019, 02:56 PM
  #1512
Correct,
With TC's currently it's the opposite. There a few brands of springs most seem to use for TC regardless of chassis. Xray, SMJ, and Axon are the few I've seen ran with xray being the most commonly brand of spring used
STLNLST and DavidNERODease like this.
Old 05-28-2019, 03:05 PM
  #1513
belt tensioner
part no. A2223
Old 05-29-2019, 03:18 AM
  #1514
tom1974's Avatar
tom1974 is offline
Old 05-29-2019, 03:27 AM
  #1515
tom1974's Avatar
belt tensioner
part no. A2223
which are the sprigs use?
Xray number....
smj number....
axon number....
tom1974 is offline
