F1 prototype 2017
Hi everyone,
I repost this to not make it disappear under the flow of messages in the "1/10 R/C F1's...Pics, Discussions, Whatever..." thread, and also to post updates :) So, here is the story: as I got bored waiting for the 3Racing FGX 2016, I decided to make my own car based on what I would like to see on a 1/10 F1 RC. So I learned on YouTube how to use Solidworks and then I designed the car. It was a very stunning experience, which took some times (started in february 2017) but now the first "real" prototype is here (3D printed parts, thanks Shapeways), and I'm pretty proud of my work :blush: So here are the main specs of my car: - 200mm wide (no other option due to technical reason, but as the real F1 are 2m wide, that's ok) - fully belt driven rear transmission (from motor to transmission axle then from transmission axle to gear diff), so there is no "classic" pinions or spurs - Spec-R gear diff with Xray T4 gear diff holders - rear indepedent suspension, based on the 3Racing FGX (only one shock at the rear on the pictures but there will be 2) - rear anti-roll bar ready - monoshock front suspension (not sure of the result, I took my inspiration from what it's been done on large scale 1/5 F1), but I also developed a more classical front independent suspension with 2 shocks that fits under the body - fully adjustable rear suspension (camber, toe, caster,...); Awesomatix style - fully adjustable front suspension (Awesomatix style) - 2 positions for the battery: longitudinal (as shown on the pictures) with winglets for ESC and RX, but transversal is also possible - 3 ways to mount the servo: fixed to the chassis and to the upper plate (as shown on pictures), fixed (chassis) or floating (upper plate) - use of traditional front and rear wing (like Montech, Serpent,...) https://img11.hostingpics.net/pics/2...oto2017V11.jpg https://img11.hostingpics.net/pics/5...oto2017V13.jpg https://img11.hostingpics.net/pics/8...oto2017V12.jpg https://img11.hostingpics.net/pics/7...oto2017V14.jpg https://img11.hostingpics.net/pics/4...oto2017V18.jpg https://img11.hostingpics.net/pics/6...oto2017V15.jpg https://img11.hostingpics.net/pics/2...oto2017V16.jpg https://img11.hostingpics.net/pics/1...oto2017V17.jpg All my creations are protected by copyright! Regards, G-rem |
Some reactions from the "1/10 R/C F1's...Pics, Discussions, Whatever..." thread: (thank you all guys!)
Originally Posted by Mr Brooksy
(Post 14892811)
G-rem, that is cool! Seriously great work. I love the thought you've put into it and the detail.
Further progress reports will be exciting to see! Thanks so much for sharing!
Originally Posted by Scott_T
(Post 14892948)
Very cool G-Rem, nice to see an awesome scratch-built car.
Only question is - do sensored motors run OK in reverse? I honestly don't know. Or would it be easier to spin the motor around the other way? Look forward to seeing more progress.
Originally Posted by disaster999
(Post 14893014)
Sensored motors runs fine in reverse.
Originally Posted by wtcc
(Post 14893022)
G-Rem you old genius :lol: Nice work!
Please leak more details like how the monoshock works. Also: Was there no way to make the rear motormount lower?
Originally Posted by lagcisco
(Post 14893323)
G-rem is my hero! Great looking work
My answer to the questions and reactions above:
Originally Posted by G-rem
(Post 14893866)
(Post 14893022)
Please leak more details like how the monoshock works. Also: Was there no way to make the rear motormount lower? The monoshock works in a simple way: 1 front rocker where both left and right susension links are connected; so that it acts as a dampening system and also like an anti-roll bar. Normally, there is some lateral play on the rocker to manage one-wheel bump but guys who runs large scale 1/5 F1 always lock that play. It results in a milder front end (for 1/10, I assume I'll have to choose very good front tyres as most of time we lack some steering). As I said, I'm not sure of the result, maybe on track it will be a complete disaster, that's the reason why I also developed a more conventional independent front suspension, with 2 rockers ant 2 shocks. We'll see how it works when I hit the track ;) Regarding the rear motor mount, the position of the motor is almost good (the final version of the main chassis won't have that big cut under the motor, but only a more classical "not-opened" cutout), and I was obliged to make such a big "arch" above in order to match the height of the opposite parts as the solder tabs of the motor have to pass under...Did you see any improvement for that?
Ok, now there is one thing, which nearly killed this project for me. And I thought I could not come up with a solution. But looking at this problem now, it wasn`t a problem at all and even gave me a deeper understanding about sensored brushless motors. What am I blabbering about ( ) is that with the front-middle-motor-configuration we turned the motor around 180°. So it turns in the wrong direction. For unsensored and brushed motors this is not a problem. Just switch plus and minus cables or A & C. But a sensored motor will not turn with just changing cable position or the esc will even tell you there is a problem and do nothing. There are three steps to make a sensored brushless motor of any make switch its rotating direction:
1. Switch cable position A & C on the motor side 2. Switch sensor cable pin position: pin #2 with pin #4 on the motor side. Don't be afraid here. Just count the wires from left to right. If you did it wrong nothing will happen. Then bring it back in the original order and just count from the other side and voilá it works! Just don't change the most outter pins: pin #1 with pin #6 that is plus and minus Here is an overview: Pin#1 - ground potential (minus) Pin#2 - sensor phase C Pin#3 - sensor phase B Pin#4 - sensor phase A Pin#5 - motor temperature sensing Pin#6 - sensors feeding +5.0V [EDIT]: I finally decided to switch the motor position, makink it a 180° turn, in order to not have to deal with electronic modification in the sensor ;) Regards, G-rem |
And now, here are the updates:
In the V2, I corrected some minor issues that I could put under the light of the 3D printed prototype assembly and I also decided to make some improvements to the existing parts: - 180° swap motor position in order to deal with the 2-belts drive transmission without having to deal with electronical arrangements as above - battery position lowered by 1mm - 0,5mm lower position for the front and rear lower arms on the main chassis, in order to widen the setup window of the car - adjustment of the steering bellcrank - front lower arms monobloc part as reinforcement - rear shocks reinforcement part on the upper plate - ... Pictures!!! 1) Longitudinal + monoshock front suspension: https://img11.hostingpics.net/pics/8...agelongV21.png https://img11.hostingpics.net/pics/5...agelongV22.png https://img11.hostingpics.net/pics/8...agelongV23.png https://img11.hostingpics.net/pics/5...agelongV24.png https://img11.hostingpics.net/pics/2...agelongV25.png 2) Transverse + front independent suspension with 2 shocks: https://img11.hostingpics.net/pics/6...nsverseV21.png https://img11.hostingpics.net/pics/2...nsverseV22.png https://img11.hostingpics.net/pics/5...nsverseV23.png https://img11.hostingpics.net/pics/9...nsverseV24.png All my creations are protected by copyright! If you have any questions, remarks, or if you think about improvements, feel free to tell me! :) Regards, G-rem |
No questions, just Likes :nod:
Way to go, G-rem. I can still remember the FGX thread and all the modifications we did.
Cheers! |
Very nice design. My only comment is why two belts? Why not the more traditional gear set at the motor output? Gear meshes are more efficient than a belt. In fact, you could do two gear meshes and get rid of the belts altogether.
Love the overall design as well , but will have to agree with the single belt idea . just for the reason to get more ratio options. Even with a small 60t spur it will keep cg low.
Only Applause!!!
Nice car but is it legal to race? In Europe only a straight solid axle at the rear and a kingpin suspension in the front is alowed by rules.
That is slick as snot!
That is Texan for that's awesome. |
Originally Posted by glennhl
(Post 14902009)
Originally Posted by jlfx car audio
(Post 14902026)
Initially, my main objective when I designed the car was to have at least the main transmission belt driven (from transmission axle to gear diff). That was how I built my previous 3Racing FGX conversion, and it worked great, so I decided to stick to it (mainly for internal gear ratio and compatible parts reasons, like the Spec-R 34t Xray style gear diff). I know the genuine transmission of the FGX is gears driven, but when I had the car, I didn't like it much as it was, mainly because it was too noisy and the internal gear ratio was absolutely ridiculous (2,7:1)! With small motors like we are used to in F1 class, that is simply impossible to reach convenient ratios. Plus this kind of transmission uses more space than my belt drive transmission... Then, I had to deal with very little space at the rear: the general design is already far from classic "pan-style" F1 regarding rear weight distribution (as everyone know, with a RWD, the most at the rear the weight, the better), so I tried to put the motor position the most at the rear that I could, and I was obliged to choose a belt transmission also for the motor-to-transmission axle junction. The problem is that my spur gear would have collided with my upper arm... (the smallest spur gear I could find is the Arrowmax 64p 70t, with Tuning Haus pinion gears (up to 70t also!!)). But I won't have any problem to adjust my ratio at the track as I've already done ratio calculation with a 15/34 internal ratio, which means I will have to deal with "pulley motor" from 16t to 20t.
Originally Posted by Roelof
(Post 14902547)
Thanks again for your comments and do not hesitate to continue to share your opinion! :nod: Regards, G-rem |
We are brothers in mind. F1 should be a fast class not what it is now. This class should be top level racing with aero and awesome suspension. I know not many agree on this. But it doesn't matter as long as G-rem builds his dream machine and shares his dreams with us :sneaky:
News!!!
I went back in the design of the transmission in order to try if I could use a more conventional one (pinion + spur gears and belt drive). Well, it seemed to be a good idea: - regarding space, it is feasible, very close but it works! In fact that was how I drove my custom 3R FGX conversion last year and it performed pretty well. - I was able to put the battery back due to the more compact rear end. Which is always a good new! The main challenge was to determine which spurs and pinions I could use. Conclusions are good: the internal gear ratio is 15/34 or 16/34 (but this one seems very hard to put in place, so I think 15/34 will be the way to go). I can use pinions from 50t to 70t and spur gears from 70t to 80t (64dp); which give me a range of ratio from around 2 to around 3.5. Not bad if you take into account the very limited space ;) Other change is the lower floor. The aim is mostly aesthetic, but I tried to draw it so that I can, hopefully, get some aero gain. In fact, there are two separate plates of 1mm on the main chassis, which will allow me to get some clearance in corners. In addition to the floor, I designed a new rear diffusor, to match new 1:1 car regulation :) I also considered to use only one upper plate for both front monoshock setup and independant setup. As you can see on the pictures below, there are some stiffners between the upper plate and the main chassis: in front, in the middle and at the back (plus the ones that support the servo, if I use the fully locked setup). And the side floors act like longitudinal stiffners (even if it is only 1mm), so I decided to go for a 2mm main chassis in combination with a 2mm upper plate. I'm afraid a 2,5mm main chassis would be to much for low grip asphalt racing... To sum-up, here are the main features of this third prototype: - 2mm upper and lower deck with multiple stiffners in order to adjust car's stiffness. - 200mm wide. - belt driven rear transmission (15/34 internal gear ratio and range of ratio from 2 to 3.5, ideal for 21.5t blinky or 17.5t/21.5t boosted). - Spec-R gear diff with Xray T4 gear diff holders. - rear indepedent suspension, based on the 3Racing FGX (2 on-board shocks). - rear anti-roll bar ready. - monoshock front suspension or "classical" front independent suspension with 2 shocks. - fully adjustable rear suspension (camber, toe, caster,...); Awesomatix style. - fully adjustable front suspension (Awesomatix style). - 0,5mm lower position for the front and rear lower arms on the main chassis, in order to widen the setup window of the car. - 2 positions for the battery: longitudinal with winglets for ESC and RX to close the lower floor, or transversal. Battery is also 1mm lower on the main chassis. - 3 ways to mount the servo: fixed to the chassis and to the upper plate (as shown on pictures), fixed (chassis) or floating (upper plate). - traditional front and rear wing (like Montech, Serpent,...) compatible. - front lower arms monobloc part as reinforcement. - rear shocks reinforcement part on the upper plate. - lower floor + rear diffusor. Pictures!!! 1) Longitudinal + monoshock front suspension: https://img11.hostingpics.net/pics/4...nsverseV31.png https://img11.hostingpics.net/pics/5...nsverseV32.png https://img11.hostingpics.net/pics/8...nsverseV33.png https://img11.hostingpics.net/pics/3...nsverseV34.png https://img11.hostingpics.net/pics/7...nsverseV35.png https://img11.hostingpics.net/pics/1...nsverseV36.png https://img11.hostingpics.net/pics/6...nsverseV37.png 2) Transverse + front independent suspension with 2 shocks: https://img11.hostingpics.net/pics/7...nsverseV38.png https://img11.hostingpics.net/pics/2...nsverseV39.png https://img11.hostingpics.net/pics/8...sverseV310.png https://img11.hostingpics.net/pics/8...sverseV311.png https://img11.hostingpics.net/pics/8...sverseV313.png All my creations are protected by copyright! I would like to thank everyone who participates in this discussion by giving me opinions, advices,... that really helped me to improve my first designs. So do not hesitate to tell me if you have any questions, remarks, or if you think about any improvements! :) Regards, G-rem |
Longitudinal motor in middle of car "spur" on the diff, "pinion" on the motor, direct contact?
