Hudy Lathe Questions
I'm going to get a Hudy lathe, but I haven't quite decided on which one or where I'm going to get it from.
1. I'm leaning toward the Hudy Advanced Comm Lathe with V-blocks, but I wanted to ask here first about the Hudy Tech Comm Lathe. Is there a big difference in cut-quality between the two? Hudy claims that the Tech eliminates vibration, but they also say that the Advanced is already vibration-free. How pronounced is the difference between the two?
2. This is my first lathe, so I'll be starting off with carbide bits. Can anyone give me the specs for the Hudy bits? For instance, I know Integy uses AL4 1/4" C-2 bits. I'm sure the Hudy would be 1/4" C-2 as well, but I wasn't sure about the bit's orientation. I know I could ask Hudy, but since I was already here asking you fine gentlemen questions, I thought I'd take a shot.
3. Where can I get Hudy products? I know Stormer has them, but they're out of stock on the Advanced. RCAmerica/Hudy.net has them in stock, but they're selling them at the "book" price rather than "street".
Thanks in advance,
Jason B
Thanks in advance,
Jason B
Both lathes will cut great. It really depends on your budget. I own the tech lathe as it offeres greater flexibility in adjustment of the tooling guides and also has a stoping tool so you will not hit the windings.
You can get these lathes from a variety of vendors, www.speedtechrc.com, www.ashfordhobby.com, www.kthobbies.com, www.horshamrcracing.com come to mind but I'm sure they're others.
As for bits - I use carbide as they cut great and are cheap. You can use an 1/4"x1/4" AL4 C2 or 1/4"x1/4" AL4 C6 bits. Easy to order from www.mcmaster.com pg 2366.
John
John
Thanks, John... exactly what I needed! I did notice that the Advanced also has the adjustable back-stop. This is one of the primary reasons I wanted a Hudy... I don't trust my jittery hands to keep the bit off the tabs.
I have the advanced lathe and it cuts perfect everytime.
I also added this to it though to help keep the comm perfectly shimmed...
http://www.hudy.net/eshop/products/p...e&kategoria=74
It makes the Advanced truely the best I have ever seen...
I use a Diamond bit that I got off ebay...LOL...I told the guy which lathe I use and that it cuts right to left and the bit has cut flawlessly since...
Hope that helps,
-Shookie <><
Hope that helps,
-Shookie <><
I LOVE McMaster... just replenished a supply of SS screws AND bought 3 (THREE) carbide bits for my new Hudy... all for under $20 (which includes S&H).
Hope that helps,
-Shookie <><
Hope that helps,
-Shookie <><
I have bearings instead of V-block. It seems that people with V-blocks swear by them, but I have had zero maintenance issues with the Hudy bearing set-up, and it is SMOOTH.
I just picked up a Hudy Advanced Lathe at an awesome price with the diamond bit. I haven't cut with it yet, but I ran up to my LHS with it and had them run it quick... all I have to say is wow!
Question for those with the axial support... is that really necessary if you only run pretty much one kind of motor? just curious!
I run 19t and stock and i use the adjustable axial every time I cut....Love it...
-Shookie <><
Nope not a nessesity...but it makes it real nice if someone else needs a cut...
-Shookie <><
-Shookie <><
The Axial just stops it from going side to side??? <-{==}-> ???
I guess the fantom stock motors were made for this lathe then! When I mounted it up, it had NO play. Took my time doing it for my first time... my comm looks like glass!! I can't see where this axial support would help me?? I couldn't believe the shaping of the comm with no cutting.. I've never done it myself so I hadn't a clue. I dont think I'll ever run a motor right out of the package again!
Originally Posted by Anthony.L
The $100 Cobra has a backstop. I've used the Hudy Tech lathe and honestly can't see a difference for twice the money over the Cobra.
WORD...........
It eliminates any possible vibrations...
-Shookie <><
-Shookie <><
Anyways only thing I can say that sucks is that the adjustable fixture is an option to buy. Not sure if hudy sells their lathes with the adjustable fixtures as standards. This means the lathe setup itself can go for 350.00 if you bought it brand new in a store. (hudy lathe, hudy diamond bit, hudy adjustable fixture)
