NEW MTS/RACE OPT 4WD MINI >
Like Tree7Likes
Old 12-22-2017, 10:49 PM
  #16
tony gray's Avatar
Originally Posted by Airwave View Post
I think you are missing the rear blades... Could be a problem...
Missing in THAT photo yes, but they are on the car now.
LIVE BUILD of the X RAY version of the MTS Mini (essentially the same thing) at 19.30 tonight (Aust Eastern Standard Time) here
tony gray is offline
Old 12-27-2017, 10:00 PM
  #17
tony gray's Avatar
https://www.youtube.com/watch?v=ASW6EJug-FU
Bartolo Racing likes this.
Old 01-11-2018, 07:22 PM
  #18
Bartolo Racing's Avatar
Trader Rating: 16 (100%+)
Have some parts in stock lmk
Attached Thumbnails NEW MTS/RACE OPT 4WD MINI-mini.jpg
Marcos.J likes this.
Bartolo Racing is offline
Old 08-05-2018, 04:33 PM
  #19
I saw that this can be used to convert a hobbyking blaze r2. Does anyone know if this or the xray conversion would work on an RGT R2? Or any other cars these could be used on? MTS kit seems discontinued and buying a T4 to convert is ludicrously expensive.
varmint is offline
Old 08-05-2018, 04:55 PM
  #20
gigaplex's Avatar
The RGT R2 is very similar to the Blaze, though you may run into issues with the servo mount as I don't thing the RGT has the floating mount. Other than that, you need a custom top deck to convert the Blaze and RGT. Bezerk has the design for it, courtesy of Tony G. The rest of the conversion should work fine.
varmint likes this.
gigaplex is offline
Old 08-05-2018, 10:46 PM
  #21
thanks! Some of the RGT editions come with a floating mount so they are out there, likely an MTS one would fit as well. I see now why the topdeck doesn't work. I have a spare fujin 211go deck I may see if I can fit it and contact bezerk if I can't.
I like these conversions because you can make them 225mm wheelbase while all the purpose built mini 4wd are 210mm
varmint is offline
Old 08-07-2018, 03:50 PM
  #22
tony gray's Avatar
This is the conversion we did. I've had to do it as a pic as Hotlinking doesnt seem to be allowed any more?
