fading
fading
this weekend my car starts fast and starts to fade. what i'll doing wrong and how do i fix it! George. fantom 25.5 amp draw 6.4 Gearing 96/41 x 1.9 = 4.448
at 386 raceway
at 386 raceway
Old batteries ?
new reddy 5600 Lipo Factory 6500. temp is 137 to 141 degrees timing 54 speedo hobby wing V3 120A shot track Xray T4 2017
Absolutely correct... Overreving is just as bad as overgearing....
40 x 76 track size. i set all my motors this way this only started when i got this fantom 25.5 i have use tekin novak and never had this problem thanks guys
Why would you arbitrarily set all your motors this way? In all likely good you are over times and over geared. Are you running USVTA or F1? Most USVTA your final gearing is between 3.5 and 4 for most tracks and motors. And very rarely is timing more than 45 degrees on any motor from the factory. Tekin, and naval may not set the timing to a particular spot, but Motiv, Fantom, TS, and other race oriented companies set the timing at its optimum (or very close to it) spot before it gets shipped out.
I race VTA I've run Novak, Trinity, TSR, and I have a new Fantom but I haven't raced it yet. Trinity is the only one of those motors running the timing above 50` makes a performance difference. I check actual timing most of the above mentioned motors have a sweet spot in the 45` range. Timing the motor up is over rated I went down that path for too long at great expense and fustaration. I am positive after many testing and racing days it's in the gearing. It is the spur and pinion combination I have chased my tail used my friends some of the fastest guys in Central and Northern Calif, timing and gearing recommendation. I found gearing conservatively timing conservatively made the biggest performance gains on the track. Top end speed is overrated being pulled 3 or 4 feet down the straight away is nothing but being pulled 3 or 4 feet out of every corner or even a couple of corners will get you lapped.
i don't run vta i run 25.5 club race if don't set my motors up like this i get lap i doing 11.3 lap time and the motor come off at 123 to134 degrees i use a Gforce analyzer to set my timing to get 6 amp draw the timing is not the same on all motors just the amp draw at 6 amp look on you tube under Gforce thanks
