Yokomo spring rates
Yokomo spring rates
I just purchased some Yokomo springs for my cars. I bought pink, purple, blue, and black. I know everyone prodominately runs pink/blue. I know the order of stiffness. What I can't find difinetivley (I've googled and get different rates for the same spring) are the actual spring rates. I'm a bit OCD when it comes to knowing this. I would also like them so I can swap out my current spring with the closest comparable Yokomo Spring. Could anyone help me out?
Thanks in advance
Thanks in advance
There is a more complete chart available here
Keep in mind, the Petitrc chart was made in 2008. Some of the current springs weren't even being manufactured at that time. That chart can help but can be confusing as well. Take the Yokomo purples for example, if you look at the chart you will see yokomo purples with a high spring rate. Those are not the current Yokomo purples that are part of the (L) series.
They don't look the same because purple has .25 more coil like you said but the spring tester says they are the same rate.
HPI silver is a quite progressive spring!
http://www.rcweb.de/index.php/Thread/17416-Federmessung/?pageNo=1
In this german forum i (The worst) have made some graphics and comparisons...
Maybe you convert language with google...
There are many T4 setups on Petitrc that use progressive fronts and linear rears. Seems popular for carpet and higher traction tracks
