Old 11-20-2002, 12:09 PM   #1
Default Associated Lightweight Diff Assembly TC3 ....
Anybody use these? I was getting ready to rebuild my diffs., and was curious if anybody had tried them yet.
Greg
GKHTC3 is offline   Reply With Quote
Old 11-20-2002, 01:10 PM   #2
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Oh yeah, works great. They now come in all TC3 models. The out drives seem to wear fairly quickly in mod, but they are very cheap to replace.
Jack Smash is offline   Reply With Quote
Old 11-20-2002, 06:41 PM   #3
Claydoh's Avatar
Send a message via AIM to Claydoh
Yeah, one pair of $5 diff halves lasted all summer for me running 19t. They wear better than the alum ones for sure
Claydoh is offline   Reply With Quote
Old 11-20-2002, 07:39 PM   #4
Thanks for the input everyone. Much appreciated. Is the standard diff., actually the 'Lightweight', I am referring to? It is all plastic, afterall. Maybe I have had the Lightweight all along, and didn't even know it. Anyway, I went in again, tightened both diffs down, then backed out the bolts a half a turn - per the manual. I think my rear diff. requires 'new' everything. We ran a little today at lunch. At first, all seemed fine (working with my new KO Propo radio), but then the car seemed to be slipping at take off. A buddy of mine noticed a different sound, and you could see, it was slipping. A whole new assembly costs about $20. I'm thinking, I will redo both front and rears. I do not have any extra diff balls. So; I can only do a partial rebuild.
Greg
Old 11-20-2002, 08:22 PM   #5
Yes, they are very light but do wear extremely quickly. After only racing 2 meetings using an 8 turn there is heaps of slop in the outdrives!!!
ixlr8nz is offline   Reply With Quote
Old 11-21-2002, 05:12 AM   #6
dw
The standard plastic diff is the lightweight diff. Old cars had steel outdrives instead.
It is normal for the adjustment on the diffs to back off when you first use them after rebuilding. It takes a while for the parts to seat. If you readjust your diffs they should be fine unless you have been running them loose for any length of time.
There is a way to reduce the amount the diff backs off.
After you build the diffs you should apply throttle whilst holding one wheel. This will help seat the components. You must then check the diff adjustment again.
The diff may back off when you run it but it won't back off nearly as much.
dw is offline   Reply With Quote
Old 11-21-2002, 05:22 AM   #7
[QUOTE]Originally posted by dw
Thanks, and good morning! I will check that this morning. After I finished adjusting the rear diff. yesterday, it is kind of tight right now. Where if you turn one of the rear wheels, the other turns the same direction. but if I back out the screw anymore, there seems to be slippage. Maybe the diff balls, and maybe even that gear are worn out. When I rebuilt them recently, I didn't replace the diff. balls, and I know you should. One of the D Rings wasn't seating real well on the outdrive. The outdrive seemed to be rounded, so it wasn't a perfect fit.
Since my TC3 is about 1.5 years old, and I don't think the diffs. have ever been completely replaced, maybe it would be a good idea to just buy new diffs., and replace everything.
Greg
Problem with diff assembly...please help. Paul Whalen Electric Off-Road 3 12-27-2007 07:57 PM
looking for one-way diff assembly JRC R/C Items: Wanted to Buy 0 02-15-2006 11:19 PM
NTC3 LightWeight Diff Outdrives cockerill Nitro On-Road 7 02-01-2006 08:15 AM
NTC3 LightWeight Diff Outdrives cockerill R/C Items: Wanted to Buy 1 01-31-2006 02:11 PM
Losi Bk2/mf2 Lightweight Diff xxxtracer R/C Items: For Sale/Trade 18 09-21-2004 05:24 AM
