Most Powerful 21.5T, 17.5T, and 13.5T Motors? >
Like Tree85Likes
Old 06-25-2019, 07:00 AM
  #121
sbd
Originally Posted by Lonestar View Post
Interesting... on both my T4 ('17 and '19), any motor mounts pretty darn close to that super-thin layer of CWF left where they've milled the chassis... not sure how I could mount anything any lower, really, offset mounting points or not? Can you explain what I'm missing? Thanks!
The diameter of the motor is by about 2 mm smaller compared to conventional motor. Without an offset the motor will appear to be 1 mm above the plate. The holes are offset such that you have motor's downside exactly at the same position as any conventional motor. The upper side of the motor is 2 mm lower and the CG (shaft) is again 1 mm lower.
sbd is offline
Old 06-25-2019, 07:44 AM
  #122
Default Lowrider
gigaplex likes this.
DavidNERODease is offline
Old 06-25-2019, 07:50 AM
  #123
Considering that chassis manufactures make a big deal out of lowering a piece of carbon fibre by 0.5mm... these SMC motors have a massive influence on the CG of the car in comparison. Besides the now obvious lower mounting, you can see from the pics that the mass of the stator will move inboard. Plus the motor is much lighter so again you gain in all areas chassis performance. I'm putting a SMC Lowrider in my Awesomatix to build the ultimate CG/polar moment car.
Old 06-25-2019, 12:17 PM
  #124
Smc lowriders really lower the CG, but will it be legal for long ? It looks like a 380 can with lots of glue around it....
bertrandsv87 is offline
Old 06-25-2019, 12:54 PM
  #125
No glue, just superior design.
Old 06-25-2019, 02:59 PM
  #126
I though this as its meant to be 540 can but just a quick look in brca rules did not see can size as a rule
plz post if I missed it in the rule book as aid only a quick look
tcboy1983 is offline
Old 06-25-2019, 03:07 PM
  #127
It is 540, just doesn't have a "can".
Old 06-25-2019, 03:11 PM
  #128
Lowrider is ROAR and BRCA approved.
Old 06-25-2019, 03:42 PM
  #129
I was under the impression that all the motors had to have a 36+mm can or outside dimensions of sorts... Yeah I guess it's ok for racers to run their motors without a can, just as long as it is glued together properly...I put CA on my aluminum motor screws to prevent stator shorts, is that legal or can I legally just glue the can together without any screws at all ??? What about plastic, carbon or tungsten rotor shafts ??? Rotors are the only parts we really need from the motor; all the other parts are 'optional' and subject to removal, right...Would a wireless stator be legal under the current rules ??? I guess it is legal when X company does it, regardless of the written rules....
I know we're still a few decades away from motorless propulsion, but come on guys, this motor should be the next 'catch of the month'.....lol ....
Old 06-25-2019, 04:35 PM
  #130
gigaplex's Avatar
How about you actually read the rules? They're available online.
Marcos.J likes this.
gigaplex is online now
Old 06-27-2019, 02:57 AM
  #131
Lonestar's Avatar
Trader Rating: 14 (100%+)
Thank you for the clarification. That's bloody trick. Kudos to SMC for that....
... and i'm tempted, I have to say. That LCG stuff will have a LOT more influence than any hypothetical 0.1% extra HP...
thank you
Lonestar is offline
Old 06-27-2019, 03:55 AM
  #132
sbd
thank you
I agree with you. I have been using SMC for the last 6 months and I am very happy with it.
As for the CG is even better - the motor is 10-15 g lighter than a conventional motor. So if you don't change anything else on the car but the motor, you will have to balance the chassis. You put the balancing weights as low as possible (on the chassis and under the motor CG). The overall effect will be even lower CG of the overall mass related to the motor than what the offset holes suggest.
DavidNERODease likes this.
sbd is offline
Old 06-27-2019, 08:16 AM
  #133
JoeyE's Avatar
Trader Rating: 45 (100%+)
I see a lot of people selling off their R1 21.5T V21 motors. What's the new hot motor currently trending now?
JoeyE is offline
Old 06-27-2019, 10:51 AM
  #134
DesertRat's Avatar
Marcos.J, sbd and gigaplex like this.
DesertRat is offline
Old 06-27-2019, 10:52 AM
  #135
Trader Rating: 16 (100%+)
I think they may be selling off their V21's because the BRCA outlawed them and people are thinking that ROAR may follow.
glennhl is offline
