Most Powerful 21.5T, 17.5T, and 13.5T Motors?
#48
Technically soaking up all the Rctech knowledge is better than cheating...It's summer now and nitro racing time....
The 40g rotor(shaft material change is legal) might be the next revolution, and all prototypes get secretly tested in regular club races: not considered cheating at all.....
#49
#51
It is the same as changing from steel to aluminum screws, no biggie....It does not matter how they made the aluminum screw, and the steel screw was not modified: same for the rotor shaft, as long as the magnet is the same, you're legal according to the Roar rules...I believe that the shaft has to be a single material with no holes or cavities in it...
#52
#54
Its funny, though I typed what I typed I was also thinking what you said to me to myself. I get the point of the thread but a balance of power and setup is typically the key is most races.
Regardless I just got a 13.5T motor to replace a 9.5T motor on my new YZ4. I got an R1 13.5 V16 motor...and the reason I got it is because some dude on YT did a bunch of dyno tests and said it was a bad boy
I look fwd to racing in a stock class with my new toy.
Holy thread necromancy! Anyway...since we're here...
I'm pretty sure we are all aware that if you drive better, your lap times are better. Why is it that every single time, ever, when a person asks a motor question, someone has to pipe up with "drive better?" If the guy wanted advice on driving that's what he would have asked ffs.
the lessons being learned are that it isn't always clear-cut which motor is faster, because there are many many variables to account for. It will always be the case that if you drive better, you will go faster. This is true in every class, in every car, with every motor, at every track. This is not a useful answer when someone is looking for help in making the car objectively faster.
Cripes.
Cripes.
#55
if its not illegal it will be. the difference is dramatic but too low of an inertia ratio is just as bad as too high of an inertia ratio. anywhere from 1-10 to 1 for continuous accel/deceleration. up to 30 to 1 for a mix and 60 to 1 for power. what you will see is cogging if its too low, traction loss and bad efficiency. if its to high it wil feel soggy and unresponsive. go too far and you get hot or smoke the esc.
at the extremes the motor doesnt feel the drive train (low inertia ratio) or the drivetrain has over damped the rate of change the motor is capable of. (High inertia) drive train with low rotor inertia,
when esc’s get as powerful as there big brothers feed forward (predictive) temp control or dynamic notch filters control the inefficiencies.
#56
Bry, I understand your point about the extremes of the inertia world, but an extra 10g to 14g close to the center of rotation of the rotor will not push the inertia to the extremes, but it might be enough to make a visible difference on the track...I am pretty sure that if it ends up being around a 40watt difference, then all the manufacturers will jump in and push Roar to approve the new change in shaft material for Bert's sake...lol....
#57
in the other thread I said I suspect a low inertia drive train would be helpful and i described what you would feel if you went too far. i then described what you would feel in the opposite direction. im not trying to disagree or totally agree, If it was on my radar i would do the math. Im simply providing you with descriptions that help you do your on track testing.
rotor inertia is not something that is intuitive. racing is torque and power and most people use a stop watch to figure out what works for them (which is fine). there is an order to what you have to understand if you want to understand inertia matching (beyond testing for improvements). it starts with understand how torque is delivered at every rpm on a curve a matching what can be delivered to what is needed. there are a couple guys on here that are all about the curves but are still thinking about how to balance the curve against what a track needs. once the connection is made a bell will go off and it wont spread like wild fire because you have to really want it to go into no mans land and there are alternatives. That is only the first mental revolution that is down the road. Then you find out that profound understanding of matching torque to track requirements is not as important as inertia matching. if the first and second concept doesnt eliminate all motivation the 3rd and 4th ones will.
Keep testing inertia. you are certainly inspired and there is allot to be gained, if you run into a wall work around it, there is still more to understand about torque that would make workarounds easier if you get stuck that will still be here.
#58
Im not telling you that you skipped something that you should go back to and understand first. i tested concepts that were out of order in robotics way back when that motivated me to do more. Some old guy was always telling me im doing it wrong and i proved them wrong. Now im that old guy doing the same except I remember that i didnt listen and as messed up as it was behind it all was something more important. Anybody who invest the time into going against some predominant concept is developing motivation and a will to succeed. Or they dont, but im only going to push the order of things enough to give people who need a motivational challenge room while at the same time not demotivating guys who arent waiting for an old guy to tell them they have no clue. Do your thing. Its reasonable.
#59
In terms of inertia isn't the rotor shaft considered on the drivetrain side of the equation? The rotor shaft is something the magnet has to move. I thought one side of the ratio is just the mass of the magnet.
On the inertia matching it isn't rocket science. You want the drivetrain as light as possible, while still being able to have components durable enough to withstand the forces you are putting through them. At that point track layout and grip levels will dictate final gear ratio and timing settings.
Each track is different and there are a multitude of adjustments that you can make to lower your lap times, which is ultimately all that matters. It is way easier to swap a pinion or change timing than to adjust the inertia ratio. Additionally, how you drive the car has a big impact on setup and performance. We have a 1/18 latrax rally spec class and I can take the controller from some guys and knock 2 seconds off their fastest lap with their own car. If I set their car up for my driving style I could get even more time out of the car. Good drivers carry corner speed, which means the less you slow down, the less you have to speed back up. If you get motored on the straight it's because you were slow through the corner before.
If you race at one track, once you are in the sweet spot you don't have to make wholesale changes. If you regularly go to different tracks then wholesale changes are usually necessary.
Bri195 have you set any lap records yet?
#60
A light weight drive train may give you more effective torque by over powering the drive train. This can work well. But a 1:1 or 10:1 is not .5 to 1. Too little drive train inertia is bad. I explained previously.
hmm, do I sense some competitive conversation on the horizon? As far as records it’s probably the ratio of what I know to what I actually use in rc. I practice and understand. The two aren’t exclusive but I certainly practice more than experiment. I’ve already done that and I know where priorities are right now.
I got frustrated with my usgt car and tuned the heck out of the motor and drive train. It’s faster than my 17.5 now and in a straight line it can’t be beat. But the motor exceeds my skill and setup. I’ll leave the motor the way it is and I’ll focus on the setup and practice. Having too much motor kind of forces you to improve other things. It’s not a bad thing to push yourself as long as your realistic about the big picture.
im not trying to be the smartest guy who ever typed about motors. I’m pretty soft on false information because I want to encourage. I’ll push a little on guys who need adversity to motivate because that is what I needed back in the day but what I didn’t know then is that when you get old you get tired of it. I probably missed allot in the way I squeezed old guys for knowledge.
