Old 01-14-2006, 10:13 PM   #16
Send a message via AIM to R/C Anonymous
composite or FT in the back and stronger ones in the front!!!
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-14-2006, 10:27 PM   #17
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Well Im not going to replace my CVD's until I break them.
How do I go about getting the Steering Arm off...not off the caster block, but off the other part? Theres a screw, I unscrewed it, theres a pin holding it on...how would I get that pin out?
Michael Barch is offline   Reply With Quote
Old 01-15-2006, 07:35 AM   #18
ChadCapece's Avatar
Look at the assembly manual, and read it right from left (backwards) so that will show you how to disassemble that part.
ChadCapece is offline   Reply With Quote
Old 01-15-2006, 01:56 PM   #19
I got it thanks.
Old 01-15-2006, 06:25 PM   #20
calstarjig90j's Avatar
You're bound to break parts one way or the other. Alumiinum replacement parts cost more, add weight, tend to bend and stay bent. Stick with plastic if you're prone to many crashes, go to carbon when you are good to go. Remember though that even if you have a bad crash sometimes the obvious broken part also hides hidden broken or bent stuff. (i.e. bent hingepins, bent axle stud, tweaked chassis, all sorts of stuff) Always make sure the parts on the car are always good to go. Sometimes folks forget that their parts can fail and lead to a crash. Something to think about. Invest on another second hand car as backup parts so that when you do break something. It won't be an unexpected parts buying frenzy.
calstarjig90j is offline   Reply With Quote
Old 01-15-2006, 06:38 PM   #21
koabich's Avatar
Send a message via Yahoo to koabich
I didn't read all the other posts but honestly, if you are breaking rear A Arms, you need to slow down and practive driving first before worrying about aluminum. Breaking stuff in the front is common on any car. But breaking the stuff in the rear usually means your rear is swinging around and smacking the wall...this means a lack of control and/or a bad set-up.
Slow down!
koabich is offline   Reply With Quote
WTB ALUMINUM HOP UPS adamjrdad R/C Items: Wanted to Buy 3 06-17-2008 08:58 AM
All aluminum beautiful mini t for sale, GREAT car, aluminum chassis and everything!!! t to the maxx2 R/C Items: For Sale/Trade 10 12-12-2005 05:09 PM
chassis: machined-aluminum vs. hard-anodized aluminum Dr Gonzo Electric Off-Road 2 11-03-2005 06:50 PM
HPI NMT aluminum hop-ups F/S coastaltony R/C Items: For Sale/Trade 0 07-10-2004 04:44 PM
Broken aluminum ball end inside of aluminum rear hub - HELP! Accord Electric On-Road 8 08-02-2003 01:24 PM
