Qual Points For On Road Racing On Black Carpet >
Old 01-24-2017, 07:22 PM
  #61
gigaplex's Avatar
Originally Posted by Sir Loin
All good points to consider in our new qualifying methodology. Do you think there is a good way to prevent these or solve them up front?
I think the idea that a single lap is the decider is a flawed concept. At the very least it should be 3 consecutive laps.
gigaplex is offline
Old 01-25-2017, 07:40 AM
  #62
jason cheng's Avatar
Trader Rating: 81 (100%+)
qual points hurts the people that try different things to get faster. one wrong change and have a bad qual your of of it.
jason cheng is offline
Old 01-25-2017, 08:05 AM
  #63
Qual points just make practice all the more valuble as qualifying is now not a "safe" place to make changes to your car incase they make things worse. Qual points are reasonable at races like IFMAR, but not really a good option for national level racing. You can make the argument that ETS uses them, but that series is on a wildly different level than every race in the US.
Keep qual points in offroad. Our tracks don't change so much that points are relevant.
Danny-b23 is offline
Old 01-25-2017, 08:40 AM
  #64
Rick Hohwart's Avatar
Qual points.
Rick Hohwart is offline
Old 01-25-2017, 08:51 AM
  #65
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Our tracks change a ton in the US.
We need to go back to qual points. If the fastest run in qual 1 does not make the A in qual 4 that is a true problem.
Example Dana's qual 1st run 17.5 1/12 time at US Indoor champs( largest race to date this year) does not qualify a top 10 spot in round 4. The track while it had a ton of laps was different every round.
I am not sure how you argue that in a rocket round it does not matter, Considering the 8 of the top 10 main setting results came from rd 4, 1 out of rd 2 and 1 out of round 3.... 7 of the B main times came out of rd 4, 2 out of 2, 1 out of 3. I had to go back to the F main to find a seeding for the main that came out of rd 1.
So if you screw up rd 4 well odds are not in your favor of qualifying near the top.
Now this is a example of 1 class at 1 event. It has been the pattern I have seen for some time. But again only one example
ammdrew is offline
Old 01-25-2017, 09:13 AM
  #66
theproffesor's Avatar
Trader Rating: 66 (100%+)
If using that example to justify qual points, why run seperate qualifiers and mains? Why not just run 6-8 races and tally up the total points. It seems the results would be nearly identical.
theproffesor is offline
Old 01-25-2017, 09:49 AM
  #67
ammdrew's Avatar
Basically Reedy style?
ammdrew is offline
Old 01-25-2017, 09:53 AM
  #68
ammdrew's Avatar
Qual points is about having each round count based solely on itself. x of y rounds resulting in over all TQ and main seeding. About the only thing qual points does is make each round equal regardless of track changes.
You will always have a break out, Crash, try something wrong, loose pinion, DQ in tech or post tech. Those are all racing deals and effect any form of qualifying equally.
You could also add ladder mains or heat races to the discussion lots of options on ways to qualify
ammdrew is offline
Old 01-25-2017, 12:36 PM
  #69
Trader Rating: 88 (100%+)
It's the host track decision. Get onboard and support whatever they choose to run at that event. There are pros and cons to both, but it's the same for everyone. Racing is fun - remember?
RBLove is offline
Old 01-25-2017, 02:03 PM
  #70
JRnotEwing's Avatar
Crazy talk
JRnotEwing is offline
Old 01-25-2017, 04:53 PM
  #71
Trader Rating: 39 (100%+)
Amen brother!!
2kidsrogers is offline
Old 01-25-2017, 05:45 PM
  #72
Rob is stupid. Let's create more problems and eventually we shut racing down so we can all take up knitting. Its bad enough we have people whom hate each other in this industry..
Boostinswifty38 is offline
Old 01-25-2017, 05:59 PM
  #73
Racermac73's Avatar
For knitting are carbon needles faster than aluminum?
Racermac73 is offline
Old 01-25-2017, 06:32 PM
  #74
No, of you knit at an increased rate of speed, then you begin "splintering" the carbon. I hear xray makes graphite counterparts with pink handles that work well.
Old 01-25-2017, 07:40 PM
  #75
Lol
RBLove is offline
