Old 01-12-2006, 11:57 AM   #1
Default PLEASE HELP WITH ICE
MY ice is starting to realy freak me out [1] the alarm does not sound anymore when battery is charged [ 2 ] my peak detection is set to 120f on gp 3300 so i press start and the battery AND peak detect CHANGE TO 87F WHY does it do this i have gon to factory settings [ reset] twice now and its the same it never did this before the charger is about 2 weeks old as . right now as far as im concerned its A SHI$ CHARGER yes i have the sensor [not that it helps much] NOW IVE JUST DONE ANOTHER CHARGE AND IT PEAKED AT 97F
serpentrush is offline   Reply With Quote
Old 01-12-2006, 12:53 PM   #2
RCMits's Avatar
Trader Rating: 25 (100%+)
the ice isnt a "shizz" charger, perhaps you have a defective unit? ill let the true ice owners chime in. if its 2 weeks old, then its under warrenty (assuming you bought it new), and you can get it serviced, or returned.
RCMits is offline   Reply With Quote
Old 01-12-2006, 01:06 PM   #3
THANKS i did buy it new and yes i know its a good charger [but not right now ] thats why i bought it
Old 01-12-2006, 02:42 PM   #4
ford_racing's Avatar
Send a message via MSN to ford_racing
to answer your number 1
if you turned off the annoying key sounds then the battery cound is trned off also, nfortunately i havn't figured out how to change it so only the key noise goes away
only a guess at number 2
the peak temp is the highest the pack will be allowed to get before the charger shuts off on the second top line it will say why it stopped charging like (not trying to shout just easiest to show) END DELTA PEAK or END CUT TEMP etc
I hope this helps
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 01-12-2006, 02:56 PM   #5
yea it used to say end delta peak ... not any more it just sits there and does nothing it charges untill they get just a little warm not hot and then starts to cool down as if the thing has stopped also no movement on display ?????
Old 01-13-2006, 11:32 PM   #6
Ghostfit's Avatar
It would help loads if you let pple know what your charging setup is.
..like did you select normal charge (Reflex/Normal or repeak) or Step charge or cycle mode ! .....the ICE is a pretty complex charger for the price and it really pays to spend the time to read up on the manual.
Ghostfit is offline   Reply With Quote
Old 01-13-2006, 11:35 PM   #7
[COLOR=Red] i have gon to factory settings [ reset] twice now
how do you do a factory reset?
thanks
XingXing is offline   Reply With Quote
Old 01-14-2006, 06:26 AM   #8
factory setting hold the 2 yelow buttons down and switch off charger
Old 01-14-2006, 06:33 AM   #9
charge @ 5 amps peak sensor @5mv/c trickle charge off temp cut out 120F max charge cap @150% top off 500 peak delay 3min and i do have the sensor probe
Old 01-14-2006, 07:10 AM   #10
BringItOn's Avatar
I hope this helps
ay, isnt the the button sound and the end melody sound different?
so you can turn off button sound, but still have the end melody (and vice versa)
i.e on the menu function it says
Button sound ..... ON/OFF
Melody Sound ..... Off/5sec/10sec/15sec/20sec
BringItOn is offline   Reply With Quote
Old 01-14-2006, 07:14 AM   #11
BringItOn's Avatar
just an idea, try removing the temp probe. maybe its malfuntioning.
so long as you have your setting right, and dont goto sleep whilst charging, there is no real need for a temp probe
Old 01-14-2006, 07:33 AM   #12
TRIED THAT STILL THE SAME
Old 01-14-2006, 02:14 PM   #13
On everyone's ICE that I know of the buttton sound also switches off the melody its the same with the supernova competition
ARC R11
Yokomo YRF001
AE B5m
