Old 01-11-2006, 08:57 PM   #1
fjm9898's Avatar
Default jaco 2 stage foam question
i just got my first 2 stage tires from Jaco. i got 12th scale tires. i am looking at the tires and i see the two different layers. my question is once you wear through the first layer do you have to toss the tires out? is the car going to handle differently once you wear into the last layer?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 01-11-2006, 08:57 PM   #2
Send a message via AIM to rcguy2477
Yes, after the outer layer is gone, they are basically done.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 01-11-2006, 09:01 PM   #3
fjm9898's Avatar
wow that sucks... the front tires trued down and ran a few times at basically amost the 2nd layer. that is some bull because the tires seriously only have 6 full runs on them. its like you dont want to true them down at all if you dont want to go through 20 bucks a day in tires.
Old 01-11-2006, 09:25 PM   #4
ChrisP's Avatar
With the 2-stage tires you don't need to true them down as low as you normally would with regular tires.
I believe this was discused at lengthin the "Jaco Tire News" thread
ChrisP is offline   Reply With Quote
Old 01-11-2006, 09:28 PM   #5
fjm9898's Avatar
alright i guess ill have to be more careful about it. whats a good starting point for 12th fronts? 46mm?
Old 01-11-2006, 09:50 PM   #6
Number 11's Avatar
Frank there is a 2 stage thread with all the info you need bud.
Number 11 is offline   Reply With Quote
Old 01-11-2006, 09:52 PM   #7
Number 11's Avatar
Here it is.
http://www.rctech.net/forum/showthre...ght=jaco+stage
Old 01-11-2006, 10:26 PM   #8
Michael Barch's Avatar
Send a message via AIM to Michael Barch
I used them tires, garbage...they cracked easily. Soon as the first layer was gone, the tires were gone. :tdown:
Michael Barch is offline   Reply With Quote
Old 01-11-2006, 10:52 PM   #9
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Cyans and Megentas Hands down
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-11-2006, 10:58 PM   #10
ChrisP's Avatar
The top layer of the tire is the only one intended for use.
I've been running the 2-stages and they feel fantastic on our track. They will not necessarily be the tire for all trackas or conditions, so use your discretion.
I do still also keep regular single stage dbl pink and dbl pink/orange tires on hand in case conditions change..
Jaco Dble Pink 2-stage foam tires rraden R/C Items: For Sale/Trade 19 02-01-2008 01:48 PM
Jaco 26mm 2-stage Sedan Foam Tires.. BSchorr R/C Items: For Sale/Trade 9 12-17-2007 08:00 PM
10 Pair Jaco 1/10 Sedan Foam Tires JAC5156 DBL Pink 2 Stage 26m donny R/C Items: For Sale/Trade 3 09-10-2007 08:55 PM
JACO 1/12th Scale 2 Stage Foam Rear Tires and wheels James35 R/C Items: For Sale/Trade 3 03-23-2006 01:50 PM
