Old 01-10-2006, 11:29 PM   #1
2001C5's Avatar
Default GFX with clear back plate
I cut a piece of plexiglass to replace the black panel on the back on my gfx. Does it need holes for the fan to move air or are the opening on the side of the case good enough?
2001C5 is offline   Reply With Quote
Old 01-10-2006, 11:45 PM   #2
RCMits's Avatar
Trader Rating: 25 (100%+)
id give it a hole or so to give it more room to move air. i also (myself) changed the fan to a more powerful output so it would be a bit more "blowy" ... is that even a word... and while your at it, use a fan that has a led in it.. makes everything glow ;-)
RCMits is offline   Reply With Quote
Old 01-11-2006, 12:06 AM   #3
asw7576's Avatar
Nice idea...... I would like to try 2 fans for better cooling. Do you have some photo ?
Old 01-11-2006, 10:13 AM   #4
2001C5's Avatar
I'll post some pics. I am going to just drill a 3" hole for now. I have some cool fans grills coming.
Old 01-11-2006, 02:05 PM   #5
DaveW's Avatar
Two fans fit well with a little modification to the case. There is some ribbing that needs to be dremeled out of the way for two fans of the same size as the original fan to fit. The LHS will have some small red JST male/female connectors that you can solder inline and to the PC board to make removal and repair ALOT easier for future projects/repair. Since the fan wire goes through the heat sink... it can be a pain to do what you want when disassembling the entire GFX. The connectors remove the weight of the fan(s) from the wire and off of the PC connections. The backplate needs holes for each fan installed... if it doesnt then it will feed little air to the heatsink and overheat the unit. The led fans are cool...but honestly dont usually move as much air as a standard fan of the same size. If you want color just add some in case lighting... there is plenty of room to do what you want in there.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-11-2006, 02:46 PM   #6
RCMits's Avatar
i made a power supply box outta an old t30 case. put one fan in the back, and sho-good'd two on the sides (near the slots) and fit a 15 amp astroflight inside..... the thing stays REALLY cool with 3 fans.. ;-)
i do agree.. LED fans are not as strong.
Old 01-11-2006, 03:30 PM   #7
2001C5's Avatar
Does the fan on the back of the gfx push air out or pull air in?
Old 01-11-2006, 03:54 PM   #8
Mine pulls air in and blows across the heatsink.
John Warner is offline   Reply With Quote
Old 01-11-2006, 05:17 PM   #9
RCMits's Avatar
pulls in... and then my side fans push out :P
Old 01-11-2006, 09:51 PM   #10
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
mits: you have a GFX?
killer89 is offline   Reply With Quote
Old 01-11-2006, 10:23 PM   #11
RCMits's Avatar
i wish i did.. i only have a T30.. im actually in the market for a T35bl or a GFX one day.. ;-)
Old 01-11-2006, 11:50 PM   #12
2001C5's Avatar
I put the clear back on and here is a pic. I have not cut the holes yet. Here is a pic with the stock plate on as well. I plan on using the modware fan grill below. It should be here Tuesday.
GFX with clear back plate-3652_reg.jpg   GFX with clear back plate-dsc00208.jpg   GFX with clear back plate-dsc00209.jpg
Old 01-12-2006, 07:40 AM   #13
Does the factory fan blow in or blow out ?
erock1331 is offline   Reply With Quote
Old 01-12-2006, 07:41 AM   #14
2001C5's Avatar
It appears to blow in. I was surprised that it was not blowing out.
Old 01-12-2006, 07:46 AM   #15
that probably explains why the back plate is always covered with dust. if it blew out then the dust would be inside the case which would not be a good thing.
say you replace the fan, is it as simple as cutting the red and black wire from the old fan, and just soldering the wires back from the new fan?
TM323 Back plate rcdude69 Nitro Off-Road 1 06-01-2008 10:51 AM
O.S. 18 tz back plate mjs3350 Nitro Off-Road 0 07-17-2007 07:17 AM
Back plate for .21 Joe Maxey R/C Items: Wanted to Buy 0 11-09-2005 01:05 PM
FS: CE GFX 35 with clear back plate and led fan corwin R/C Items: For Sale/Trade 9 04-27-2004 06:08 AM
Comp Electronics GFX 35 Charger with led fan and clear back plate corwin R/C Items: For Sale/Trade 2 03-14-2004 11:39 AM
