Old 01-10-2006, 10:16 PM   #1
R40Victim's Avatar
Default What do I have to do to keep a Pro 4 together when...
I just installed the GTB 5.5 brushless system. All I've done is run a simple bench test with the motor installed. The shaft vibrated so vilolently I haven't bothered to drive it. My Q is, am I gonna have to upgrade to a carbon fiber shaft? And if so, what else can I beef up? This new system makes my 19T chameleon look like a wore out 540! Can't wait to track test...
R40Victim is offline   Reply With Quote
Old 01-10-2006, 10:23 PM   #2
scoobydo's Avatar
Are you sure you had the O rings installed in the center shaft drive cups?
I've had the Pro4 since it came out and I have never run into that problem.
scoobydo is offline   Reply With Quote
Old 01-10-2006, 10:29 PM   #3
R40Victim's Avatar
Just checked, yup. It doesn't look bent either, hardly moves at lower rpms. With the old 19Ts I was running, it didn't spool up that high, and never happened. It looks like the shaft itself is just flexing alot. That's why I'm asking about the carbon fiber upgrade.
Old 01-11-2006, 01:37 AM   #4
Nicadrauspro4's Avatar
Try upgrading with the HPI Carbon Fiber shaft. But it's good for 12T and above only. If you want a better and tougher carbon shaft for your pro4, check out this link in this site:
http://www.rctech.net/forum/showthread.php?t=66286
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 01-11-2006, 02:10 AM   #5
Frank McKinney's Avatar
If it 'hardly moves' it's still moving!!
So you have a bent shaft.
The graphite one is the next best thing, there is a bit of give, but before getting that try the o-ring mentioned above.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 01-13-2006, 07:57 AM   #6
Trader Rating: 198 (100%+)
A bent shaft will cause your problem. Mine does the same thing. I am going to up grade to the one on RCtech at some point. Or change to a T2
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
