Tamiya Euro Truck Class >
Like Tree867Likes
Old 03-21-2022, 06:38 PM
  #1411
IndyRC_Racer's Avatar
I believe that all of the Tamiya Eurotruck bodies REQUIRE the use of the long wheel base which is 257mm. If you don't use the long wheelbase, then the wheels WILL rub on the rear wheel arches which make the car almost impossible to drive.
Tamiya does make a few bodies such as the Porsche 911 GT3 that uses the short wheelbase of 251mm
IndyRC_Racer is offline
Old 03-21-2022, 07:06 PM
  #1412
OK, thank you for the quick reply. I will go with long wheel base then. It came with a fat fox body
Tdrake694 is offline
Old 04-11-2022, 08:05 AM
  #1413
agentorange's Avatar
Hey not to bring it up again if already answered but I run on smooth medium traction surface. Question is is anyone using any traction compound and does it work well with these trucks. Just was curious to see what traction compound works the best on asphalt and if there any draw back to using it.
agentorange is offline
Old 04-27-2022, 06:49 AM
  #1414
JCarr's Avatar
Default New esc
I had an esc go bad in my truck and noticed new trucks are coming with the hobbywing 1060 in them. Does that mean they are now legal to use as a replacement? I can't seem to find any updated rules about this change.
JCarr is online now
Old 04-27-2022, 08:51 AM
  #1415
R/C Tech Elite Member
mrreet2001's Avatar
https://www.tamiyausa.com/tcs/rules/
16.5 Must use the kit supplied Tamiya TBLE-02S/TBLE-04S ESC/THW-1060 Brushed Motor ESC (2-3S) Hobbywing OEM-Same as QUICRUN 1060 BRUSHED ESC (2-3S).
Even if it wasn't in the rules, I support the use of that ESC for 2 reasons. Some kits ship with it and for safety reasons ( I don't like an ESCs without a LIPO cutoff).
JCarr likes this.
mrreet2001 is offline
Old 04-27-2022, 08:55 AM
  #1416
JCarr's Avatar
Originally Posted by mrreet2001
Excellent, thank you so much.
JCarr is online now
Old 04-27-2022, 09:44 AM
  #1417
always make sure to check the PDF for rules updates. It's updated much more quickly than the website. you can find the updated rule under article 16:
  • 16.5 Must use the kit supplied Tamiya TBLE-02S/TBLE-04S ESC/THW-1060 Brushed Motor ESC (2-3S) Hobbywing OEM-Same as QUICRUN 1060 BRUSHED ESC (2-3S).
JCarr likes this.
JoshuaRC10 is offline
Old 04-27-2022, 12:03 PM
  #1418
The Tamiya TBLE-04S esc DOES support Lipo cuttoff. Please refer to the following link for more information (including a PDF manual that can be downloaded).
https://www.tamiyausa.com/shop/elect...hless-esc-04s/
Here is a link for the Tamiya TBLE-02s esc (no lipo cutoff)
https://www.tamiyausa.com/shop/elect...02s-brushless/
I have raced indoors with the TBLE-02 in Eurotruck with no issue. The key to using an ESC without Lipo cut-off is to pay attention to how long you are racing/practicing the vehicle between full charges. At most typical indoor electric races/tracks a fully charged lipo battery will not discharge enough to be an issue. However there may be instances where someone is racing for an extended amount of time or on at a very large track where over-discharging may become an issue. I would recommend that everyone run a "test" race time, then check to see how much energy is left in the battery (either using their charger or a lipo battery checker).
I would recommend anyone who is concerned with over-discharging their lipo batteries when using an ESC without low voltage cutoff that they purchase an external lipo low voltage alarm. They can be found easily online.
Old 04-27-2022, 12:50 PM
  #1419
mrreet2001's Avatar
That doesn't help a forgot to charge situation or a situation where your truck has more drag then normal such as a bound drivetrain
I do run one, because it's asinine to run a Lipo without protection. With all of the "Safety" rules put into place by ROAR, I am surprised it's even legal to run a Lipo without protection.
Also the QUICRUN 1060 is a heck of a lot cheaper.
Old 04-29-2022, 05:45 PM
  #1420
GerryH's Avatar
Trader Rating: 26 (100%+)
Tamiya TBLE-02s does have LVC. Never had a chance to test it. On a technical track, the brushed motor will overheat before you run out of battery capacity and on a big open track, you can run 20-25 mins on a 4600mah battery. So still way longer than needed.
GerryH is offline
Old 04-30-2022, 10:18 PM
  #1421
Rastaracer's Avatar
So much fun today, for never racing outdoor onroad asphalt, (only indoor carpet for me.) having 15 trucks in the class and qualifying 5th in the A, I battled back and forth for second and third ending a 1/10 sec behind second place.
Ripon rc speedway is a good spot with great racers and well kept race program.. funtimes.
94SRUNNER likes this.
Rastaracer is offline
Old 05-01-2022, 10:16 AM
  #1422
Here are the low voltage cut-offs for the ESC (Electronic Speed Control) that have been included with Tamiya Eurotruck kits.
- Tamiya TBLE-02s (https://www.tamiyausa.com/shop/elect...02s-brushless/)
Protection systems: overheat, overload, low voltage to 4.8V (LiFe battery only) Note: Does not support Li-Po 6.0 voltage cut-off
- Tamiya TBLE-04s (https://www.tamiyausa.com/shop/elect...hless-esc-04s/)
LOW & HIGH Battery Low Voltage Protection Feature: LOW battery setting cuts off @ 5.6 volts approximately. (Best for Ni-CD, NI-MH and Li-FE battery chemistry) HIGH battery setting cuts off @ 6.2 volts approximately. (Best for other battery chemistries)
Here is a good article that discusses using a Tamiya TBLE-04s (https://www.thercracer.com/2021/05/t...ontroller.html)
- Hobbywing THW 1060 BRUSHED ESC (2-3S) (https://www.hobbywingdirect.com/prod...c-2-3s-brushed)
Low Voltage cutoff for 2s is listed as 6.0v in the manual (https://cdn.shopify.com/s/files/1/01...03ENG.pdf?3141)
Here is a quick chart based on information I found on the manufacturers websites & manuals
Tamiya TBLE-02s item# 45057
- LVC = 4.8v (does not support 6.0v LVC for Lipo batteries)
- Brushed & Sensored Brushless Motors
Tamiya TBLE-04s item# 45069
- Low LVC = 5.6v (Ni-CD, Ni-MH, Li-FE)
- High LVC - 6.2v (Works with Li-PO batteries)
Hobbywing THW 1060 Brushed ESC item# 30120201
- LVC = 6.0v
- Brushed motors ONLY
While the TBLE-02s does have a LVC (low voltage cutoff) of 4.8v, it is only suitable for protecting Li-FE batteries.
The TCS Eurotruck racing that I have participated in the USA has always used Li-PO batteries and brushed motors. Since the heats/mains have only been 5 minutes long, over discharging batteries has not been an issue for any participant (that I am aware of). However you never want to over discharge Li-PO batteries as it could damage the battery and create a possible fire risk. To minimize this risk, any individual racer or track can could restrict the ESC being used in their racing to have the appropriate LVC for the battery chemistry that is being used.
I hope this information helps.
Old 05-13-2022, 05:54 AM
  #1423
Are diff fluids tcs legal? I see they are used but not specifying if it's at tcs events.
V8 Rumble is offline
Old 05-13-2022, 07:03 AM
  #1424
mrreet2001's Avatar
This would be the "loophole" that allows it:
16.15 Any grease, or lube may be used to lubricate gears, or moving parts.
Old 05-13-2022, 07:54 AM
  #1425
gigaplex's Avatar
Except diff oil is not a grease or lubricant. It has the opposite effect of lubrication.
gigaplex is offline
