Tamiya Euro Truck Class >
Like Tree867Likes
Old 06-14-2021, 08:41 PM
  #1336
Trader Rating: 24 (100%+)
Originally Posted by izzyracer
Yesterday TCS racing. Euro Truck Amain, Enjoy!
What changes were made to make the semi better for you?
chjosi is offline
Old 06-14-2021, 09:35 PM
  #1337
izzyracer's Avatar
Trader Rating: 27 (100%+)
Did a better job glueing the side wall all the way to the edge on the front tires. Preventing the car from over flicking on tight corners and consequently traction rolling. After that I was able to drive it harder.
RRto997 likes this.
izzyracer is offline
Old 06-15-2021, 07:16 AM
  #1338
xpressracer's Avatar
Great video, what camera were you using?
xpressracer is offline
Old 06-15-2021, 07:26 AM
  #1339
izzyracer's Avatar
go pro 7, superview 4K 30 setting
Old 06-17-2021, 10:56 PM
  #1340
RRto997's Avatar
Congrats Izzy. You looked good out there!
RRto997 is offline
Old 06-18-2021, 07:00 AM
  #1341
izzyracer's Avatar
thanks
RRto997 likes this.
Old 06-18-2021, 10:59 PM
  #1342
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Good job Izzy!
Thanks for the video
You got me from the git go man, I tried so hard to catch you guys, obviously too hard LOL, sorry for the bumping and over driving but that was a super fun race.
Look forward to doing it again soon.
izzyracer and RRto997 like this.
F N CUDA is offline
Old 06-18-2021, 11:02 PM
  #1343
izzyracer's Avatar
Originally Posted by F N CUDA
Good job Izzy!
You bailed too early man. We missed you at the podium. Got your tool stand printed. See you next time.
Old 06-18-2021, 11:07 PM
  #1344
F N CUDA's Avatar
Yeh I was dog tired and cut out as soon as my races were over this time
Thanks for remembering me with the tool stand, looking forward to using that, it looks trick
F N CUDA is offline
Old 07-08-2021, 11:43 AM
  #1345
Trader Rating: 15 (100%+)
Under TCS rules, is traction compound allowed and, if so, what is the best one to use on low grip asphalt when the ambient temperature is around 75 F?
aft53 is offline
Old 07-08-2021, 12:13 PM
  #1346
R/C Tech Elite Member
mrreet2001's Avatar
Tire conditioners are allowed, but may be restricted at certain TCS venues. (Some TCS host sites do not allow additives due to ventilation issues)
As for which one... Your best case is to ask people at the track if possible. There might be a goto for that particular track or a restriction.
mrreet2001 is offline
Old 07-08-2021, 06:29 PM
  #1347
GerryH's Avatar
Trader Rating: 26 (100%+)
Nothing in the TCS rules regarding traction compound. It's left up to the track. Some tracks has strict rules on which ones are allowed. If you're racing outside, I'm guessing it's open. But you should check with the track.
GerryH is offline
Old 07-09-2021, 06:15 AM
  #1348
mrreet2001's Avatar
Direct from the TCS rules (see #1):
TIRE & WHEEL RULES
  1. Tire conditioners are allowed, but may be restricted at certain TCS venues. (Some TCS host sites do not allow additives due to ventilation issues)
  2. Tires may not enter the TECH inspection area in a wet condition.
  3. Tire warmers are not allowed in the tech inspection area. They may be used after the car has passed technical inspection.
  4. It is not permitted to drill extra wheel vent holes for the purpose of altering the performance and grip level of the tire. Enlarging the existing vent hole is also prohibited. Exception: In the F-1 rubber class, when using items 1031 and 1032 (high grip rubber tires) on Tamiya wheels that don’t have any holes (e.g. Tamiya foam wheels), it is permitted to drill one hole. Note: The hole may not exceed 2mm in diameter.
  5. Any tire insert may be used in classes that have OPEN Tamiya tire rules.
  6. “Spec” pre-mounted rubber tire classes may not remove the installed insert.
  7. It’s prohibited to apply super glue on the horizontal surface of the tire to alter traction characteristics. Exception: In the Euro Truck class you are permitted to glue up to the first horizontal groove/tread of the tire from the outside edge.
  8. Running rubber tires with no inserts is permitted and legal in the open tire classes.
  9. Asphalt Surface Races: GT-2 & GT-1 classes: House Spec Tire Rules. See Matrix Below for Specific Location House Tires used.
  10. Carpet Surfaces Races: GT-2 & GT-1 classes: See Matrix Below for Specific Location House Tires used.
  11. M-Chassis, Euro Truck, GT Novice, and GT Pro Spec must use the specified Tamiya branded tires called out in the class specific rules. See class specific rules.
  12. F-1 class: This class may use the host site “HOUSE” tire of choice.
Old 08-14-2021, 11:30 PM
  #1349
RRto997's Avatar
What batteries seem to be the best batteries for Euro Truck?
RRto997 is offline
Old 08-17-2021, 02:19 PM
  #1350
DARKSIDE's Avatar
https://www.associatedelectrics.com/...0mah_35c_7_4v/
RRto997 likes this.
DARKSIDE is offline
