Tamiya Euro Truck Class >
Like Tree867Likes
Old 02-11-2021, 10:29 AM
  #1306
GerryH's Avatar
Trader Rating: 26 (100%+)
My family has ran TT01s for over 10 years and haven't had a problem with the driveshafts. Getting the rear gear in can be a pain and I'm guessing you used some force to get it in based on your comments which did probably bend it slightly. It can rattle around and outside of the Eurotruck class, I've used a Tamiya dogbone foam spacer on one end of the drive shaft to take out some of that play.
GerryH is offline
Old 02-13-2021, 08:42 PM
  #1307
WhiteLX's Avatar
New driveshaft fixed the noise.
fleetmaster and 94SRUNNER like this.
WhiteLX is offline
Old 02-14-2021, 05:57 AM
  #1308
jgraham37128's Avatar
Trader Rating: 25 (100%+)
‘where did you get the parts?
jgraham37128 is offline
Old 02-14-2021, 11:54 AM
  #1309
WhiteLX's Avatar
Amain
https://www.amainhobbies.com/tamiya-...005713/p752924
WhiteLX is offline
Old 02-18-2021, 01:01 PM
  #1310
I ordered mine should be here Saturday. I did have to bend mine to get it in. Didn't think it would affect it but it did.
Old 02-18-2021, 01:13 PM
  #1311
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
We kicked off our euro truck last summer and I think two of the guys had a wobbly center driveshaft too, one of which was really bad. A replacement shaft cured it.
Dan is offline
Old 03-10-2021, 01:30 PM
  #1312
thirtydaZe's Avatar
Trader Rating: 38 (100%+)
Thinking about getting back in to a truck. Buggyra or Cabover? I prefer the cabover look, but does the other constantly out perform it?
thirtydaZe is offline
Old 03-10-2021, 02:34 PM
  #1313
MD
MD's Avatar
Trader Rating: 136 (100%+)
The racers I know who had th cabover have switched to the Fire Fox.
thirtydaZe likes this.
MD is offline
Old 03-10-2021, 02:57 PM
  #1314
Trader Rating: 23 (100%+)
Cab over is king at my track
speed90 is offline
Old 03-10-2021, 03:23 PM
  #1315
Trader Rating: 39 (100%+)
I've run both and think it may be track dependent. The Cab Over definitely feels more in the carpet and sensitive to steering input. The FatFox is also fast but it feels more on top of the surface. It all depends what you like. I was a diehard FatFox guy until I tried the new Mercedes. I like them both.
speed90 and thirtydaZe like this.
Jamie Hanson is offline
Old 03-10-2021, 06:23 PM
  #1316
WhiteLX's Avatar
20 Minute A-main at Revelation Raceway this past weekend. I always feel like we should have some Benny Hill music playing
WhiteLX is offline
Old 03-10-2021, 10:32 PM
  #1317
MikeO's Avatar
Mercedes > Fat Fox > Man
Merc is the best between the steering of the Man and the easygoing handling of the Fat Fox
MikeO is offline
Old 03-10-2021, 10:47 PM
  #1318
Dan
Dan's Avatar
Do you race on asphalt or carpet?
Dan is offline
Old 03-10-2021, 11:08 PM
  #1319
MikeO's Avatar
Very low traction carpet. Home Depot carpet off road track, jumps removed, no sauce. When the weather was in the 70’s-80’s (Fahrenheit) I was gluing sidewall to the beginning of the first tread block with the Man body. But that was as much traction as we ever had.
Ran back to back Man Vs Merc on one truck and then ran the same set up on a Fat Fox (dads truck) for comparison.
MikeO is offline
Old 04-20-2021, 03:57 PM
  #1320
tboned_2002's Avatar
what was the end result. Which body was the best on your local track?
tboned_2002 is offline
