Tamiya Euro Truck Class >
Like Tree868Likes
Old 01-09-2020, 11:42 AM
  #1126
nrtv20's Avatar
Originally Posted by mrreet2001
Where are you running at? I haven't seen any Proteks yet at One Eighth Racers.
Still in the build phase for euro but running other Tamiya stuff at a small track in Norwalk so I have the Peak packs. Want to bring the trucks to Toledo before the year is out, but just asking the internet before I get some new batteries.
Thanks everyone for the updates.
nrtv20 is offline
Old 01-10-2020, 05:32 AM
  #1127
R/C Tech Elite Member
mrreet2001's Avatar
At one eighth I have noticed the following will have the biggest effect:
-The silver can lottery
-Driving Style
-Tire Prep
-Diff prep
The batteries were pretty much equal unless we run the 15 min main like we did at the end of the last season. We have even swapped batteries with each other.
mrreet2001 is offline
Old 01-10-2020, 11:19 AM
  #1128
What's the minimum weight in this class ???
bertrandsv87 is offline
Old 01-10-2020, 11:25 AM
  #1129
There was a minimum weight at the TCS race I went to. But unless you're cheating, it doesn't matter. A naked truck, with a mini servo, and micro reciever still clears the minimum weight by tens of grams.
Nerobro is offline
Old 01-10-2020, 12:44 PM
  #1130
I agree with the Silver Can lottery. I have one that is particularly fast among many. There was nothing special that I did to it.
Dealer Xing is offline
Old 01-10-2020, 12:52 PM
  #1131
mrreet2001's Avatar
You may not add weight. You may not remove weight.
These are the TCS rules that most places roughly follow:
-Legal kits: Item 58632 Team Hahn Racing MAN TGS (TT-01 type E chassis), 58642 Team Reinert Racing MAN TGS (TT-01 type E chassis) & 58661 Buggyra Racing Fat Fox (TT-01 type E chassis)
-The kit must be built EXACTLY per the instruction manual.
-The ONLY Hop-Op Options permitted are Ball Bearings (ANY BRAND) and a Tamiya servo saver.
-Must use the stock pinion and spur gear.
-Must use the kit supplied Tamiya TBLE-02S ESC
-Must use the kit supplied motor (item 54358 RS-540 Torque-Tuned Motor)
-Battery connector on ESC may be changed to DEANS type.
-The Motor Bullet Connectors may not be removed.
-The ESC & Motor wires may not be shortened!
-All body parts must be used.
-All screws in the kit must be used. I.E. You may not omit screws to change the handling of the truck.
-No Minimum or Maximum Weight: No weights of ANY KIND may be put on the truck for ballast.
-Adding FOAM material to the kit foam bumper is permitted.
-Must use kit type tires and wheels. Note: Kit tires may be glued onto wheel.
-Any grease or lube may be used to lubricate gears or moving parts.
-Batteries: Any stick-pack type, hard round case LiPO, NiCD, or Ni-MH is permitted. Examples: Reedy Wolf-Pack or Peak Racing Powermax batteries.
-Any Tamiya Hi-Torque Servo Saver is Permitted.
94SRUNNER likes this.
Old 01-10-2020, 06:02 PM
  #1132
Thanks for posting the rules....Very interesting....
Old 01-12-2020, 10:56 AM
  #1133
Finished everything but adding a receiver and a battery.
hobbyten, G4ZZ4 and Cornfield like this.
Jeff H is offline
Old 01-12-2020, 11:02 AM
  #1134
Nice paint and decal work!
Primeval is offline
Old 01-12-2020, 05:49 PM
  #1135
Thanks!!
Jeff H is offline
Old 01-15-2020, 07:21 AM
  #1136
ironzgti35's Avatar
Trader Rating: 33 (100%+)
Anyone know where to get a 24t spline insert for the stock servo saver? I have a few Hitec's laying around but the kit only has 23t and 25t inserts. Local track enforces the stock servo saver rule
ironzgti35 is offline
Old 01-15-2020, 07:45 AM
  #1137
SteveM's Avatar
Trader Rating: 165 (100%+)
I have never seen one to fit the Tamiya servo saver. You are stuck with Futaba or Airtronics splines.
SteveM is offline
Old 01-15-2020, 07:47 AM
  #1138
TCS rules allow the HD servo saver.. does the do 24 spline?
Nerobro is offline
Old 01-15-2020, 08:01 AM
  #1139
SteveM's Avatar
None of the Tamiya servo savers have the 24T spline. They fit either Futaba, Tamiya or Sanwa, JR, Acoms and KO
Nerobro likes this.
SteveM is offline
Old 01-17-2020, 08:39 AM
  #1140
nrtv20's Avatar
Originally Posted by nrtv20
Is the Protek battery the only competitive option now? I have a few Peak powermax 4200s available to use but am ready to purchase new packs. Obviously 2 peaks vs 1 Protek is a benefit when I have to pit 3 trucks.
2 down 1 to go...
Nerobro, Jeff H and 94SRUNNER like this.
nrtv20 is offline
