Tamiya Euro Truck Class >
Like Tree867Likes
Old 08-17-2019, 02:27 PM
  #946
I use team associated 1m in the front and it does not leak. I wouldn’t run anything lighter. I tried that before and it leaked out and made a complete mess. I run the rear open and handles well. The fastest guys at our track also run open rear. I tried diff putty before and it seems to dry out and sip out in powder so it won’t make a mess but I prefer the oil now because of less maintenance than having to refill putty.
ebohon is offline
Old 08-17-2019, 02:29 PM
  #947
Originally Posted by sps3172
1) After mounting the tires to the wheels, add a coating of glue to the FRONT TIRES ONLY in the area mentioned in this article:
Spec Truck Tire Glue Rule Change | ETRL
2) FILL the FRONT DIFF with this white grease:
Bad Horsie Diff Locking Grease - For all RC open-differential designs
3) Use this grease (shoot for 1/2 to 3/4 full) in the REAR diff:
https://www.homedepot.com/p/Lucas-Oi...0005/202521504
We have several of these trucks running at Prolevel RC in St. Louis. These simple changes make the eurotrucks drive MUCH better on the black carpet.
Iíll have to try the red stuff. What sort of difference did you get from it? I donít think the trucks diff out rear do they?
ebohon is offline
Old 08-17-2019, 03:53 PM
  #948
The rear is where they diff out. THey're quite front heavy.
Nerobro is offline
Old 08-19-2019, 10:54 AM
  #949
tortes's Avatar
Default Tire glueing
How much of the sidewall are you guys glueing on the front and rear wheels for running on crc black carpet? How much of the inside sidewall of the tires as well.
tortes is offline
Old 08-19-2019, 11:41 AM
  #950
Start with the full outside sidewalls. They allow the outer tread on the tires now. If you glue the outer tread up front, you should be fine. I would err to getting as much traction as I could, so softer sidewalls is good.
Nerobro is offline
Old 08-19-2019, 10:35 PM
  #951
We only glue the outside of the front tires.....nothing on the inside or on the rear tires at all. I always suggest that guys DO NOT glue below the top of the TAMIYA logo. The best working tires at our track typically have glue from the top of the Tamiya logo to the inside edge of the first tread block.
sps3172 is offline
Old 08-21-2019, 09:37 PM
  #952
The norm that works well at our track at TQ seems gluing the outside fronts only with the first top thread. Iíve tried different amounts on the sides from an F1í style in the edge and all the way to the rim... didnít notice a difference. However prior to tamiya changing the rules on the top thread, the amount on the sides did make a small difference for me. I also then glued the inside fronts and it was way to much loss of traction and the truck understeered to the point of making it worthless. That made the wheels to stiff. I have a sander so it was easy to remove with exacto knife edge while the wheel turning. Stick with the outside front and nothing rear and that should work fine.
ebohon is offline
Old 08-30-2019, 12:02 AM
  #953
Trader Rating: 39 (100%+)
Hi,
I was just wondering if there are any difference between the three Tamiya racing trucks other than the different body sets?
Daniel
$$$... is offline
Old 08-30-2019, 05:23 AM
  #954
No, all the same as far as the running gear goes.
The two cab-over bodies are the same, besides the livery.
Bloke is offline
Old 08-30-2019, 09:18 AM
  #955
eR1c's Avatar
...mechanically they are the same, body wise there are 2 body styles, and it has not been proven that either is better in terms of performance. I am still winning w/ the original style cab over body (against a crowd of mostly V2 newer body styles).
eR1c is offline
Old 08-30-2019, 10:54 AM
  #956
What surface are you on?
Nerobro is offline
Old 08-30-2019, 04:33 PM
  #957
Thanks for the reply.
$$$... is offline
Old 09-02-2019, 07:04 PM
  #958
jhold87's Avatar
Trader Rating: 26 (96%+)
Default No brakes
Anyone have issues with the electronics out of the box?I have zero brakes and I have reset the ESC and tried every radio setting and still have no brakes. Thanks for any help.
jhold87 is offline
Old 09-02-2019, 07:54 PM
  #959
You might have a bad ESC thatís happened to one our guys we tried everything we could think of... finally bought a new one and issue fixed immediately.
ebohon is offline
Old 09-03-2019, 09:04 AM
  #960
eR1c's Avatar
asphalt at all the clubs I race w/
eR1c is offline
