Tamiya Euro Truck Class
#634
Who's interested in running these trucks.. with trailers? Does that interest you?
I have some ideas on how to build the trailer, but I need some more information to "get it right" Like, how much the trailer should weigh. What a "single axle" trailer should weigh? Obviously it should use euro truck wheels and tires.
#635
I'm refreshing my truck, and I'm out of Tamiya diff grease, and out of associated clear grease.
Is there anything else I can use or should I get some more tamiya / associated grease?
running on indoor, non a/c black carpet, currently has low traction
#637
grease for the diffs. I run everything else dry (shocks, drive cups)
Our track changes in traction, in the summer time it gets greasy and traction goes down due to heat the humidity. In the winter time traction goes up......
#639
Read Over Thread #519 for setup.
#641
Yep, however if you put aside the gray area stuff and look at what he did to get the tranny smooth etc and putting in 25 mil to make the front diff like a spool pretty cool stuff. Both of these were within the rules just not the ballast under the arms
#642
did a 3D printed Cab for my FPV.
Naked with CAB off. cages is useful for mounting the font blinkers and tidying the cables.
from the front
another use of the bar for netting
side view.
low-res video from the FPV. Can see the whole windscreen, even the dashboard dials!
from the front
side view.
#643
that is awesome!
#644
it’s an interesting idea. But would take a lot to actually get the idea to work. It’s more then just making a trailer. The track would be need to changed radically to make any kind of turns. And considering that from what I’ve seen on liveRC, Euro truck class has disappeared
#645
