Tamiya Euro Truck Class >
Like Tree867Likes
Old 03-28-2018, 06:38 AM
  #541
JCarr's Avatar
Originally Posted by redmonster27
Hey John
I don't see anything that says minimum weight of 1450 or anything about adding weight I know it's illegal but the rules u posted and the rules i have don t say anything about weight minimum or maximum. Is that how your truck drives so smooth u have weight in it huummmmm? Lol
No added weight in my truck, just built per the instructions and driven like I stole it. I'm even using the smaller Peak 3300 45c battery. Though thinking about getting a new battery now looking at the rules.
JCarr is offline
Old 03-28-2018, 06:39 AM
  #542
Trader Rating: 88 (100%+)
Get to Work!!!
JCarr likes this.
MUDVAYNE is offline
Old 03-28-2018, 06:40 AM
  #543
JCarr's Avatar
Originally Posted by Teamhotrods
But adding for balance is OK? Just looks like they worded it to allow some weights.
Yeah, they do leave A LOT of gray area there. Guess if they want no weight added they need to put a max weight as well.
JCarr is offline
Old 03-28-2018, 12:13 PM
  #544
Tim Neja's Avatar
Yeah a little suspect there? HEAVY ballast VS SOME ballast? It does seem a little vague! Like it's okay to have some ballast to enhance handling as long as it's not EXTREME!!??
Tim Neja is offline
Old 03-28-2018, 12:30 PM
  #545
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
We used to get about 12 trucks at our local club then slowly every one started to bend the rules a little so now we are lucky if we get 4 trucks now , sold mine because of it , how hard is it to follow the rules and race it how it comes out of the box
JCarr and Darkgenerals like this.
Marcos.J is offline
Old 03-28-2018, 12:36 PM
  #546
R/C Tech Elite Member
Darkgenerals's Avatar
Trader Rating: 67 (100%+)
Darkgenerals is offline
Old 03-28-2018, 12:40 PM
  #547
Super Moderator
Marcos.J's Avatar
Originally Posted by Darkgenerals
Darkgenerals likes this.
Marcos.J is offline
Old 03-28-2018, 12:44 PM
  #548
Not relevant to the thread, but your meme game is always spot on.
Marcos.J likes this.
Old 03-28-2018, 01:21 PM
  #549
I saw a guy with half a pound of balast on his chassis. He was fast, but not "fastest". And even awful driver me was able to put some distance on him coming out of corners.
Nerobro is offline
Old 03-28-2018, 01:31 PM
  #550
YoDog's Avatar
Trader Rating: 28 (100%+)
Hey John
Really??
It's right there at #8.
Tamiya has cleared up some grey areas (battery qualification) but still needs to clearly define the gearing and weight rules with more detail. It won't take much.
Maybe something like this?:
4. Must use stock pinion and spur gear specifications. (Pitch and tooth count)
8. Weight :Min = 1450 grams, Max = 1500 grams (Adding heavy ballast for low CG is prohibited).
A maximum weight will also effect battery capacity since this has not been defined in the battery spec. This can also negate people using under battery weight plates and then argue they need to add more weight to balance the chassis.
YoDog is offline
Old 03-28-2018, 02:47 PM
  #551
c-lyon's Avatar
Mine weighs 1518, including added foam on the bumper.
c-lyon is offline
Old 03-29-2018, 12:19 AM
  #552
NOT LEGAL I just build it for bashing and occasional trolling around the track
Attached Thumbnails Tamiya Euro Truck Class-whatsapp-image-2018-03-29-13.42.15.jpeg   Tamiya Euro Truck Class-whatsapp-image-2018-03-29-14.04.00.jpeg   Tamiya Euro Truck Class-whatsapp-image-2018-03-29-14.21.13.jpeg   Tamiya Euro Truck Class-whatsapp-image-2018-03-29-14.21.13-1-.jpeg
DarthBacon101 likes this.
cheapskate.brok is offline
Old 03-29-2018, 06:52 AM
  #553
RC_Bandit's Avatar
Question. Unable to get true center on my HiTech servo. Using SkyRC Radio. When I attempt to get center, my radio is either set to L30 max (still steers to slight right) or R30 max (still steers slight left) and still unable to get it to drive straight. Just that one notch on the spline sends the supplied servo saver to far left or too far right.
Has anyone had this issue?
RC_Bandit is offline
Old 03-29-2018, 07:07 AM
  #554
Toypainter's Avatar
Trader Rating: 110 (100%+)
I didnít have a servo adapter for Hitec in my kit. I used a medium Kimbrough
Toypainter is offline
Old 03-29-2018, 07:40 AM
  #555
DarthBacon101's Avatar
Me! I was and am still having the same issue...had me and Falconz confounded as to what was causing it...I had to adjust the steering to about 16 or 20 on my Spektrum...
DarthBacon101 is offline
