Tamiya Euro Truck Class >
Like Tree867Likes
Old 12-07-2017, 12:23 PM
  #376
Teamhotrods's Avatar
Originally Posted by Rodarbal
He used a 4x4... might be a bit more of a mass advantage than a 2x4 (momentum!).
Holy heck, he can use that battering ram to break through the EURO TRUCK clogs... I think he might be a little heavy up front!
Teamhotrods is offline
Old 12-07-2017, 12:39 PM
  #377
I watched a guy put something like 300g of weight on his truck..
Nerobro is offline
Old 12-07-2017, 02:26 PM
  #378
bdmpastx's Avatar
The 4x4 was removed after the glue cured...I thought that was obvious
bdmpastx is offline
Old 12-07-2017, 02:36 PM
  #379
TECH INSPECTION PLEASE!!
Pit-racer likes this.
Old 12-07-2017, 03:17 PM
  #380
Rodarbal's Avatar
Trader Rating: 49 (100%+)
: Good luck at CORP this weekend! The 4x4 in the truck might be a bit more obvious on the carpet!
Rodarbal is offline
Old 12-07-2017, 04:23 PM
  #381
gigaplex's Avatar
Originally Posted by JatoTheRipper
The Tamiya TT series is all about affordable, but durable vehicles. I understand that. But the TT02 is still better than the TT01 so why not use the latest and greatest version that they have?
It's not universally accepted to be a better car than the TT01E. The TT01E has a better reputation for durability, and the proposed solution of buying a TT02 then getting the truck body separately is also considerably more expensive, defeating both the affordability and durability objectives.
JatoTheRipper likes this.
gigaplex is offline
Old 12-08-2017, 10:36 AM
  #382
Pit-racer's Avatar
See you all at HobbyTown South Austin Texas this Sunday! Red Fury will be released!
Pit-racer is offline
Old 12-08-2017, 12:53 PM
  #383
bdmpastx's Avatar
I am going to try my best to get there after CORPs in Dallas.
bdmpastx is offline
Old 12-08-2017, 01:43 PM
  #384
Rodarbal's Avatar
I won't be able to race this one. But I should be there out later in the afternoon to hand off an iPad to Joe. Have fun, Pit! Get that thing broken in! I tell you, I never laughed so hard on the stand. They actually drive a lot better than I expected.
Pit-racer and GrandeGixxer like this.
Rodarbal is offline
Old 12-11-2017, 06:13 AM
  #385
JatoTheRipper's Avatar
Good information! Thank you.
I put the Man TGS TT01E kit on my Christmas list. We'll see what happens.
JatoTheRipper is offline
Old 12-11-2017, 06:30 AM
  #386
TENCHO's Avatar
my ESC didn't work for some reason... anyone have issues with the TBLE-02s ESC?
I have 2 of them and they both rapid flash red....and this was after a normal run one day, and the next day....flashing red.
manual says, check for damage.?
TENCHO is offline
Old 12-12-2017, 08:09 AM
  #387
You could try the programmign sequence again. Make sure they're set for brushed use.
Nerobro is offline
Old 12-21-2017, 07:31 AM
  #388
I had one bad straight out of the box
Homer2207 is offline
Old 12-21-2017, 07:35 AM
  #389
Body mounting--- Myself and at least one other at our club have had "issues" keeping the cab attached to the lower body.... after a few "incidents" the supplied foam tape gives out. Have tried a few things haven't found the perfect solution yet I don't think....
Looking to see what others are using and if they have had this issue....
You know who you are..... no comments on the "incidents" LOL.....
Old 12-21-2017, 07:50 AM
  #390
After my fourth race day (What's your truck? I'm Greg, I run the box blue colors..) my cab finally gave up.
Amusingly, most of the people running the euro trucks are experienced racers, and seem to have no problem whatsoever keeping their trucks intact.
I however... am a different story. For the race last sunday, I had stripped most of the white tape out and replaced it with black bolink servo tape. That, didn't seem to do as well. Tonights project, is going to be spreading a little e6000 in there, and through bolting the cab to the lower body. I plan on using six m3 nut and bolt sets, so that no individual screw will want to pull though. We'll see if that works on saturday.
I didn't have cab tape breakage issues until I put some weather stripping on my bumper, so I think that may relate to durabilty issues... eg: don't pad your bumper.
Nerobro is offline
