Tamiya Euro Truck Class >
Like Tree867Likes
Old 09-03-2022, 08:14 PM
  #1516
Default Euro truck build
Whatís up everyone. This is my first euro truck build. I pick the kit up last week and got it built and putting I. The electronics. When I am trying to mount the ESC the on off switch it to small for the spot in the chassis. Where have you guys been mounting the switch for the esc?
sckootter55 is offline
Old 09-03-2022, 09:59 PM
  #1517
Attached pic
is where I installed mine. I use gorilla tape with a pinch of shoe goo to make sure it stays put. Enjoy!
chuck in indy is offline
Old 09-05-2022, 12:22 PM
  #1518
Well I think I figured out why my truck keeps hopping so badly - the front of my Man body seems to have become extremely floppy. It seems like the few others with Man bodies were having the same issues, while the Mercedes and Fat Fox bodies were performing much better.
I'm going to try to stiffen the body up. If that doesn't work I'll have to get one of the other bodies.
Raguvian is offline
Old 09-05-2022, 04:11 PM
  #1519
Body chatter is normal on all of the bodies. It helps to run your body clips 1-2 holes higher to allow the body to move the way it needs to and not transmit those forces to the chassis.
Cromulent is offline
Old 09-05-2022, 07:40 PM
  #1520
Mine is significantly more floppy than the other two bodies.
Raguvian is offline
Old 09-07-2022, 03:18 AM
  #1521
Dan the Man's Avatar
Trader Rating: 41 (100%+)
What's the wear like on the tyres driving on asphalt? Any advantage with fresh rubber, or are they better worn in?
Dan the Man is offline
Old 09-07-2022, 10:31 AM
  #1522
i've used the same set of tires for three seasons without any apparent loss to performance. when i got new tires, the breakin period seemed to last forever until i did a VERY aggressive burn in (held the truck and let the tires smoke), after which they seemed to start working.
we're planning a euro truck endurance race for next summer and my suspicion is that a single set will last the full 4 hours no problem.
JoshuaRC10 is offline
Old 09-07-2022, 04:32 PM
  #1523
gigaplex's Avatar
My tyres haven't lasted very well on asphalt. 5 race days and they have a deep ring of death cut in them.
Dan the Man likes this.
gigaplex is offline
Old 09-08-2022, 03:12 AM
  #1524
Is that at TFTR? Are they sugaring the surface at all?
Old 09-08-2022, 03:21 AM
  #1525
gigaplex's Avatar
2 days at Bendigo, 1 day at a strip mall exhibition race in Bendigo, 1 day at TFTR, 1 day at Boronia. We're not sugaring at TFTR.
gigaplex is offline
Old 09-09-2022, 08:02 AM
  #1526
Trader Rating: 39 (100%+)
Originally Posted by chuck in indy
Attached pic
What speed controller is that? It is not the normal TBLE-02s I am use to seeing in the Tamiya kits.
Jamie Hanson is offline
Old 09-09-2022, 08:11 AM
  #1527
gigaplex's Avatar
Hobbywing 1060, Tamiya rebrands it as the THW-1060
gigaplex is offline
Old 09-09-2022, 08:24 AM
  #1528
Good to know. Thank you. I had no idea Tamiya started using these and that they are legal in the class.
Old 09-09-2022, 11:30 AM
  #1529
My Man truck came with the TBLE but all the other kits I've seen (MB and Fat Fox) have had the 1060. I swapped the Tamiya branded 1060 into mine because of its smaller footprint.
Raguvian is offline
Old 09-10-2022, 10:39 AM
  #1530
An6e1o_414's Avatar
Iím on my 4th race and I still have decent amount of tread left. Our track is reasonably smooth and they throw down watered down syrup on the track.
It also depends on how you are with the throttle. My buddy was pretty much sliding each corner while I try to slow enough to take the inside line as much as possible.
An6e1o_414 is offline
