Old 04-11-2006, 09:18 PM   #106
RCknight's Avatar
Default T2 setup for carpet/takeoff27s?
Hey, Mike what set up do you recommend for low-med grip, newer ozite carpet, and using takeoff27s? Someone recommended the DCcup setup, but I don't know the team driver's name. Any up dates since that setup? Thanks
RCknight is offline   Reply With Quote
Old 04-11-2006, 10:03 PM   #107
Send a message via AIM to Bobby Flack
RCKnight.. The setup your looking for would be Jilles Groskamps from the DHI Cup. Just this weekend I started back racing rubber tires again and that was an awesome place to start. Give it a shot.
Bobby Flack is offline   Reply With Quote
Old 04-11-2006, 11:17 PM   #108
RCknight's Avatar
Default Thank you for the quick response Flack.
Someone mentioned that the DHI Cup track had much more traction than my local track. Do you have a couple of tips for getting more traction out of the setup?
Old 04-13-2006, 05:10 PM   #109
ae4ever's Avatar
Mike , are the rocket city ball end you used at the bird's for the upper arm still avalible ? And why were you using the old asc. caster blocks?
thanks in advance.
ae4ever is offline   Reply With Quote
Old 05-22-2006, 07:41 PM   #110
Send a message via AIM to mush104
hey mike i was wondering what a good setup is to start with on foam tires and a med bite track.
mush104 is offline   Reply With Quote
Old 05-28-2006, 07:54 PM   #111
RCknight's Avatar
Default Mike???
Do you know if Xray's going to do anything soon so that we can run a Lipos in our T2s?
Old 05-28-2006, 11:00 PM   #112
new92's Avatar
Doubtful since they arent legal to race with and the Hudy's have said time and again that the T2 is a race car not a basher.
new92 is offline   Reply With Quote
Old 10-03-2006, 02:00 PM   #113
J@UNE's Avatar
Mike, congrats on your win at Vegas!!!
I heard (and saw from your setup sheet) that you were using the dbl pink all around. Was it related to the low traction? Should it be consider as a good tire combo? I always had problem getting the steering I wanted at my local track.
Thanks!!!
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 10-03-2006, 02:53 PM   #114
Mike,
What setup (can, arm, wind, brushes, springs, gearing, rear tire size, and timing) are you running in 1/12th.
Greg
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 10-03-2006, 03:09 PM   #115
Mike doesnt currently have internet access,it could be a while before he replies here. He does use the internet at the library on occasion.
Just thought I would let you know.
Lon
Lon_L is offline   Reply With Quote
Old 10-03-2006, 05:11 PM   #116
[email protected] It was something that paul L tried in vegas.. I have not tried it at the local level but it just might work.. We were having a tought time getting steering and we also were having the car get tighter and tighter as the race went on.. So this seemed to help fix some of those problems and allow us to run faster... I think the setup can be tweaked to go faster but did not want to mess with it since it was main time....
Greg... I am currently running a 10 single in the shock can .. with 12 degree's timing 4383 brush red springs tire size about 1.75 gear about 31/100.. hope this helps..
Lonnie... Thanks man...
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 10-03-2006, 05:18 PM   #117
J@UNE's Avatar
Thanks Will give it a try
Jon Gagnon
DirtTrax - Team FLR
Old 10-03-2006, 05:31 PM   #118
You're welcome bud!
Lon
Old 10-03-2006, 05:42 PM   #119
thanks Mikie... see you at the end of the month.
[email protected]
Old 10-03-2006, 05:58 PM   #120
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
internet nerd. Your just trying to get you rpost count up...
OUT
Keith Billanti is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Team Corally International Signs Mike Blackstock CorallyUSA Electric On-Road 28 12-30-2006 04:28 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
