Bittydesign 1/10 TC 190mm bodyshells! >
Like Tree470Likes
Old 07-30-2019, 12:42 PM
  #751
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Marcos.J View Post
I bought 1 pre cut after that I rather take the extra few minutes and mount the body properly and cut it so is perfect to my set up (wheelbase)
Ya because of the different set ups and such no precut will be perfect. The first one I got (M410) worked so well and required minimal modification I thought I'd go for the JP8 in a pre-cut. The $4 difference in price is a bargain not to have to cut it out, especially the wing. This JP8 just fits really strange around the wheel base. Like it was made too short. I havent measured yet but I'd be willing to bet the difference between the wheel openings is larger for the M410 than the JP8 probably by 5-7mm. They should be the same I would think since they are pre-cut for the same chassis.
RussF is offline
Old 07-30-2019, 01:48 PM
  #752
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
they should release the bodies Pre-drill for body post but with uncut wheel wells
RussF likes this.
Marcos.J is offline
Old 07-30-2019, 02:27 PM
  #753
TurnNBurn's Avatar
Hi all - any opinions on the general performance of the Striker? I’m considering this body because I’m OCD and would like to run the same body style on both my EP TC and the IC TC I plan on buying soon (since the Striker is the only 200mm body bittyDesign sells ATM). Thanks!
TurnNBurn is offline
Old 07-30-2019, 03:03 PM
  #754
RussF's Avatar
Or at least not the back wheels maybe. But they sure make a nicer cut than I do. I ended up just lengthening the rear opening. Looks dumb, but it should work ok. I'm kinda out of room to open it too much though as the little bit of the body left over at the back of the wheel opening is pretty small now. And the opening is more oval than round.
Marcos.J likes this.
RussF is offline
Old 08-11-2019, 10:54 AM
  #755
ImacFanatic's Avatar
Whats your suggestion for a shell on a large asphalt track, mixed infield and a 130' straight for the 21.5 stock/blinky tc class ?
ImacFanatic is offline
Old 08-11-2019, 11:06 AM
  #756
Super Moderator
Marcos.J's Avatar
410 is always a safe choice
Marcos.J is offline
Old 08-12-2019, 02:50 PM
  #757
RussF's Avatar
I was doing some testing during and after racing this weekend. We have a smaller asphalt track guessing about 75x40 treated medium + grip. I tried a JP8 vs. the M410 both precut. The JP8 for sure has more corner rotation than the M410. It felt more "slippery" for lack of a better term to me than the M410. I felt like I was driving faster and turning sharper with the JP8 but actually had a better race results with the M410. For my style I liked the M410 as I like a tighter car more than loose in the rear end. But I could see where the extra rotation and steering are helpful with the JP8. I didnt change setup between tests other than dropping the rear body mount 1 hole lower for the JP8 vs. the M410.
DavidNERODease likes this.
RussF is offline
Old 08-14-2019, 08:17 AM
  #758
Trader Rating: 67 (100%+)
When using the Bittydesign body trace kit what’s a safe number to start with 6, 7, 8 or 9? Thanks
Speedychris22 is offline
Old 08-20-2019, 01:40 PM
  #759
Bittydesign's Avatar
6mm mounted forward is for sure a safe position, on asphalt you can for sure place the body more aggressive than carpet, our tests example demonstrated that the JP8 drive vey fast if mounted "extreme" at +10mm, also the M410 you can push it at limit at +10 forward.
Bittydesign is offline
Old 08-20-2019, 01:43 PM
  #760
As wrote by Marco our M410 will make you always happy, it looks like a "real" car and perform good at same time, our best compromise. Need more steering? Switch to JP8 but mount it extreme at +10mm forward with 21.5 class; if you feel it's too safe, pass to the JP8HR that givs you more rotation, is has been developed for this purpose respect the JP8.
Old 10-04-2019, 01:23 PM
  #761
💥 It took a while but the moment is coming!
>>> Our all new project for the 1/10 190mm TC class will be released soon. Ready?! #October2019 <<<
Old 10-04-2019, 01:34 PM
  #762
Panther6834's Avatar
I'm probably totally wrong...but, after zooming in on the photo, I'll take a wild (VERY wild) guess that's it's Ferrari-based.
Panther6834 is offline
Old 10-04-2019, 07:33 PM
  #763
Looks like it's going to have a ton of steering
Hopscotch is offline
Old 10-04-2019, 10:23 PM
  #764
TurnNBurn's Avatar
Would love to see more 200mm versions of your 190mm shells. Personally, I’d like to be able to run the same body style between both my chassis.
Old 10-06-2019, 09:58 PM
  #765
alecladanga's Avatar
Talking
the hood is very intriguing as it is...when is the release, i'm drooling here :-P
alecladanga is offline
