Bittydesign 1/10 TC 190mm bodyshells! >
Like Tree470Likes
Old 01-25-2019, 10:31 AM
  #691
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
Originally Posted by disaster999 View Post
still one of the best compound for foam on carpet
yes sir, but many don't care for the smell these days and I don't fully blame them. Between that paragon and the old Buggy grip, I've sure had my fill. Lol
Teufel Racing is offline
Old 01-28-2019, 06:51 AM
  #692
Trader Rating: 36 (95%+)
Originally Posted by Bittydesign View Post
We participated to a recent race here in Italy, the track was indoor with perfectly flat asphalt surface and the VENOM not flex, the key was the perfect ground. But when racing on carpet situation is different and the problem you noticed could be easily fixed; in other words what you described is this:
and we resolved it by removing one screw on the topdeck and replacing it with a body post (see following pics):
that we trim close to the body to eliminate the flex, this is the result:
It cost nothing doing this, when you switch to another body shell you remove the body post, when you mount our VENOM body you remount the body post on the topdeck. Hope this can help you and others who felt the same issue.
what rims are those thanks
mracer1 likes this.
zaraz is offline
Old 01-30-2019, 02:04 AM
  #693
Shop Owner
nnick's Avatar
For a large, flowing low traction track which body would you recommend and where should it be fitted?
Also can you state starting position of
M410
JP8
JP8HR
nnick is offline
Old 01-30-2019, 06:00 AM
  #694
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
M410
JP8
JP8HR
low traction M15 works pretty good
Marcos.J is offline
Old 01-30-2019, 06:52 AM
  #695
Bittydesign's Avatar
M410
JP8
JP8HR
Nick this updated chart will help you:
Bittydesign is offline
Old 01-30-2019, 06:56 AM
  #696
Shop Owner
nnick's Avatar
Yes I found it
Recommendation on where to put each body?
nnick is offline
Old 03-01-2019, 10:51 AM
  #697
Welcome America! 🇺🇸
#JP8HR is now ROAR approved and can be used to all the races without any limitation 👊
Shop the body at AMain Hobbies and be ready for the incoming Nationals the next week 😎
🛒 Light Weight 👉 JP8HR Light
🛒 Ultra Lite Weight (ULT) 👉 JP8HR ULT
NutDriver likes this.
Old 03-02-2019, 11:17 AM
  #698
DBM
I ran the jp8hr in 21.5t tc stock on black crc carpet yesterday, along with a montech racer, type-s, and preopard. My fastest laps and best consistency came with the jp8hr. It felt much like a racer but smoother (which makes sense since the rear 3/4 of the jp8hr is 95% the same as the montech racer but with smoother features).
the only issue that i've been noticing with the jp8hr is that both of mine are twisted, as is the one that another local racer has. One of the front body mounts needs to be a lot higher in order to get the splitter to be parallel with the setup board.
DBM is offline
Old 03-03-2019, 08:23 PM
  #699
Regional Moderator
disaster999's Avatar
Edit: Bittydesign asked me to take this down since they havent released their next body yet
John Doucakis and Scott_T like this.
disaster999 is offline
Old 03-04-2019, 10:07 AM
  #700
Trader Rating: 23 (100%+)
all i know is if bitty releases a 458/488 i'm getting into USGT after years of saying no
carkillaii likes this.
phatboislim is offline
Old 03-10-2019, 05:18 PM
  #701
I now have six track days on an ULT m410 body and not a single crack anywhere. I usually run pretty clean, but today I cut the sweeper at the end of the straight tight and stuffed the car under the pipe full throttle. Still no cracks after I popped it back out.
I'm beyond impressed with the durability of this body. And it weighs 62g painted.
Oops
JeffC is offline
Old 03-11-2019, 10:27 AM
  #702
Default Rotation and Steering
Could someone please explain me the difference between steering and rotation?
Nytro is offline
Old 03-13-2019, 08:26 AM
  #703
VegasHB's Avatar
Rotation I believe is in regards to the rear of the cars ability to slide a little in a controlled manner. You want the back of the car to come around and square up on corner exit if that makes sense. Steering is obviously the front grip into, mid and out of the corner in general.
VegasHB is offline
Old 03-13-2019, 01:38 PM
  #704
Default high down force JP8 mounting
I was wondering how far forward people are mounting the HD body for a med traction pavement car?
bill
airsiler3 is offline
Old 03-13-2019, 08:07 PM
  #705
MidwestRacer's Avatar
I see they wouldn't say, but those are HPI RTR E10 wheels in gunmetal. 26mm 6mm offset just fyi. I have some. Sweet wheels, but offset and width aren't ideal for racing.
MidwestRacer is offline
