Bittydesign 1/10 TC 190mm bodyshells! >
Like Tree470Likes
Old 08-10-2018, 12:21 PM
  #556
Originally Posted by Bittydesign View Post
For 17.5 class without any doubt the ULT version, on CRC carpet the difference respect the Light weight version is big, you can keep the original Ultra Lite wing mounted backward or change it with our 'Charge' wing (but don't think this is necessary at any cost).
What is the rational behind ULT being most optimal for 17.5 stock class? I understand that lighter bodyshell will always result lower CG, but I would think modified car with higher speeds would benefit lower CG even more to avoid traction rolling. Total weight is anyway dictaded by minimum weight limit which modern cars with proper electronics can anyway achieve even with regular weight bodies.
micsa is offline
Old 08-10-2018, 12:26 PM
  #557
miller tyme's Avatar
Modified is slower speed in the corners. A stock car gets it's low lap times from good cornering, mod is usually a lot of point and shoot, then stand on the brake, turn and point again
miller tyme is offline
Old 08-10-2018, 12:53 PM
  #558
ASM
ASM's Avatar
Trader Rating: 28 (100%+)
When will we see a USGT body? Thanks.
ASM is offline
Old 08-10-2018, 01:54 PM
  #559
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
i read they are pushing for a minimum weight for bodies now ,
Marcos.J is offline
Old 08-10-2018, 02:59 PM
  #560
Minimum weight for bodies will be good only to stop companies that don't have an ULT program from going under....I guess PF is feeling the heat...lol....
The ULT bodies can still make weight by adding goop on the lowest parts of the body...
jlfx car audio and Ggrant like this.
bertrandsv87 is offline
Old 08-10-2018, 05:53 PM
  #561
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
I think of it like this ;
In mod your always looking for more grip without traction rolling (on carpet ) so softer setups more camber and more aggressive bodies ...
In spec (from 21.5 to can am tc) your basiclally trying to get rid of traction in the middle of the corner and a lighter weight body makes less grip mid corner by not making the body roll the car ... It allows the setup to be the grestest influence on grip .
Where as mod we tipically need slightly more roll innthe setup to give more corner speed when trying to point and shoot at the same time .
This is my thinking anyways
jlfx car audio is offline
Old 08-17-2018, 06:37 AM
  #562
mac853's Avatar
Could someone tell me which version of M410 is suitable with new rules of 90g bodyshell?
Best regards
mac853 is offline
Old 08-17-2018, 06:46 AM
  #563
Trader Rating: 19 (100%+)
Best regards
My Lightweight M410 with Helix anti-tuck and steel hardware is 96g with a spray bomb that's on the thicker side...
iTz Nicholas72 is offline
Old 08-17-2018, 06:55 AM
  #564
mac853's Avatar
You Mean Ultralite is surely unfit, right?
Best regards
mac853 is offline
Old 08-17-2018, 08:00 AM
  #565
thisguy2849's Avatar
according to the rules, gooping around the low parts of the body wont be allowed
Marcos.J and iTz Nicholas72 like this.
thisguy2849 is offline
Old 08-17-2018, 12:59 PM
  #566
I guess they will also not allow thicker paint jobs on the lower parts of the body then.... Nothing they can do about that, and these rules are unnecessary....
Old 08-17-2018, 01:56 PM
  #567
Super Moderator
Marcos.J's Avatar
doesnt matter you dont race anyways unless the keyboard counts
Marcos.J is offline
Old 08-17-2018, 03:19 PM
  #568
The racing season starts in September and I will be racing in mid October... It is always good to see folks here searching for an edge on the competition before the winter season starts: Bert's tenacity is getting through !!! Good job guys, and see you all at the track !!!
Benchracing always precedes real racing !!!
Old 08-18-2018, 06:56 AM
  #569
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
ULT bodies work very well in all classes of TC the lightweight is heavier and will meet the ETS rule,until there is a rule in the USA I’m sticking with the M410 ULT for 17.5 and the JP8 lightweight in mod,seems the best combination for me. ����
Warren Weaver is offline
Old 08-18-2018, 10:07 AM
  #570
I've seen the prototypes so I guess it wont be too much longer
iTz Nicholas72 likes this.
