Bittydesign 1/10 TC 190mm bodyshells! >
Like Tree470Likes
Old 07-10-2018, 09:45 AM
  #526
Trader Rating: 23 (100%+)
which is what i need. just hoping the car doesnt become too lazy
phatboislim is offline
Old 07-17-2018, 07:50 PM
  #527
Regional Moderator
disaster999's Avatar
I just got the JP8 and was test fitting it on the car. I had to do a triple take on the label to make sure its 190mm and checked the width with the ruler to make sure it is in fact 190mm. The body looks so much wider than others. Theres a good 1cm gap between the front wheel and the body. I dont remember bodies for other manufactures being this wide for a 190mm car.
disaster999 is offline
Old 07-18-2018, 05:06 AM
  #528
Super Moderator
Marcos.J's Avatar
Trader Rating: 221 (100%+)
mine looked wide also on my Gizmo but it handles very well
disaster999 likes this.
Marcos.J is offline
Old 07-18-2018, 07:42 PM
  #529
The rear wing is very wide too - right on the limit here in Australia. The M410 wing is a bit narrower (6mm from memory). Tuning options if you have one of each!
Scott_T is offline
Old 07-18-2018, 07:46 PM
  #530
Regional Moderator
Yeah Im planning on running this body on the Gizmo Beta, cant wait to test it out.
Which line do you trim the body to? Im guessing everyone will slam the body as close to the ground as possible right?
I didnt notice the wing difference, but with such a wide car it should have a wider wing as well.
Marcos.J likes this.
Old 07-19-2018, 05:28 AM
  #531
Bittydesign's Avatar
Our JP8 body shell measure 194mm wide so it's in line with others manufactures who make bodies at 192-193mm wide; the correct trim is the upper line marked on the front splitter and side skirts, follow this line and after cutting place the body at about 8-9mm height from the ground, this is the perfect setting of the body. We recommend to mount the body forwarded about 8mm, use the lines reported in the centre of the front wheel arch, the longer line is "neutral" position. The JP8 it comes with max whidth wing, if you need more rotation because you feel it's to planted on the back, reduce the wing to 18mm height and mount it more forward on the body.
Bittydesign is offline
Old 07-19-2018, 06:11 AM
  #532
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 07-19-2018, 08:55 AM
  #533
How many mm are each line in the front wheel arch? Would you recommend this same mounting both forward and height for the m410.
fanfor18 is offline
Old 07-19-2018, 10:29 AM
  #534
Each line is 2mm distance so move the body forward 4 lines to meet the 8mm overall misalignment.
Yes also the M410 need a forward placement to reach the best performance, also in this case use the lines reported in the front whell arch.
Old 07-24-2018, 10:27 AM
  #535
Bikerbob's Avatar
Bittydesign, anyone selling your bodies in Canada?
James
Bikerbob is offline
Old 07-24-2018, 12:07 PM
  #536
stanislow's Avatar
gripworksrc.com sells Bitty stuff! Quick shipping too
stanislow is offline
Old 07-31-2018, 12:57 AM
  #537
James
Black Diamond R/C will receive soon a supply of our TC shells, he will be the 1st store in North America to have on the shelves the all new JP8 ULT!
Old 07-31-2018, 01:04 AM
  #538
💥 It's finally here!!
The new JP8 ULT body shell offers addition specific improvements in handling and agility!
The Ultra Lite Technology creating a ultra light body with maintained form during the run gives you that extra edge you need in competition.
Less body roll and thus more cornerspeed to give you that extra performance.
Discover all the features about the ULT body at 👉bittydesign.net/en/jp8-ult
JP8 ULT by Bittydesign Co.
Old 07-31-2018, 07:58 AM
  #539
snopro31's Avatar
Trader Rating: 54 (100%+)
Yes we will be getting bodies as soon as they are done, if anyone is interested in the new bodies and securing one pm me to secure a body purchase of any 3 bodies will get free shipping in Canada and the U.S
Bikerbob likes this.
snopro31 is offline
Old 07-31-2018, 01:51 PM
  #540
OttoKrosse's Avatar
Can't seem to find pre-cut M410 bodies, did Bittydesign stop making them?
OttoKrosse is offline
