BSR Tires
BSR Tires
I just picked up some of John's BSR tires, opened the bag and you could smell fresh rubber. These seem to be alot fresher than the Jacos. Does anybody know if there is much difference than from the Jacos, they are only 60mm so they don't need to be trimmed much. Do the colors match the Jacos? With the fresheshness I think I found a new tire as I have come accross a few boxes of Jacos that were all dried up.
Our 10th and 12th tire compounds will be alittle different from Jaco in the color rating. Our sedan tire compounds will be very simular. We do make a xxpink/purple tire that alot of guys like to run in the rear with the xxpink/orange in the front. The narrow outer band of purple helps reduce tire tearing when you wreck with other cars or hit the boards. It also is used for tuning. Gives you another tire choice to run in the rear with the xxpink/orange front, which can be good or bad.
You can't beat BSR tires. Quality and Service is awesome. Just a phonecall away!
I can say that I have ran BSR tires in oval for quite some time.
I switched to brand x for a while and ended up coming back.
John's wheels do not break (well at least I have not had one crack or break on me) and also the foam never seems to chunk and the glue is top notch.
I have a feeling his on road stuff will be top notch too !!
Try em out
Try em out
has anyone tried the BSR setup of?
D pink orange in front
D pink purple in rear.
for med. traction carpet
Basicly I want to know. How does the feel in the corner differ for the xx pink in the rear?
Hope this helps
I didn't know this thread was here until I did a search. I've been running these tires for a couple of months now. (xx pink/orange in front, xx pink/purple in back) They are awesome. If you've never run them before, do yourself a favor and try them out. The purple ring in the back helps free up the car and definitely helps on tire wear. Great product.
Originally Posted by John Tag
Yup these tires were also used by Brandon Melton to win the 2006 Snowbirds 19T sportsman class against some big names...
