Old 01-05-2006, 10:30 PM   #1
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Arrow Rubber on low bite carpet
I am running on a track with newer carpet and very low grip, like driving on ice. Foam is not ran there so grip will not go up. An thing will help.
roadrashracing is offline   Reply With Quote
Old 01-05-2006, 10:33 PM   #2
Superkarter's Avatar
Are u running a traction compound?
If u are try changing your setup to get more bite.
Superkarter is offline   Reply With Quote
Old 01-05-2006, 10:37 PM   #3
Moderator
yes I am, I am kind of new and don't know much about what different changes make. I messed around with springs and shocks. What should you change first?
Old 01-05-2006, 10:41 PM   #4
I am sure the grip will go up if you and a handful of other guys run your rubber tyres with traction additive, Niftech, Jack the Gripper, TQ. A nice black grove should form in the carpet. Our track was like that. Driving on ice. We then allowed 1/10 scale guys to driveon our micro track. Oh boy what a difference did that make. Dropped 1.1 seconds from my previous weeks fastest lap.
tunnelhead is offline   Reply With Quote
Old 01-05-2006, 10:44 PM   #5
What tyres are you using. I have found RP's 22's and 27's work good.
Old 01-05-2006, 10:47 PM   #6
Moderator
Thats kind of how it is the black is start to form, I am using cs-27s required for major races by me. I think they change the track every week so the groves might change, I am not sure.
Old 01-05-2006, 10:48 PM   #7
Moderator
what would be a good basic setup to start out with?
Old 01-05-2006, 10:51 PM   #8
opps ment Take off CS 22 AND 27
Old 01-05-2006, 10:54 PM   #9
Moderator
It is a very tight small track.
Old 01-05-2006, 10:58 PM   #10
What car are you driving? If it is the JRXS go to www.teamlosi.com and there is a icon you can click on that will give you set up sheets. Looks pretty good. Asphalte carpet rubber and foam set ups give it a try. They should be able to get you in the ball park. I am the same a s you just learning about all this set up stuff. I find it is a lot of trial and error.
Old 01-05-2006, 11:00 PM   #11
Moderator
I've looked there, there was a setup I was running that worked on a different track. I got the xxx main book but it does not work to well for me. Thanks for the input.
Old 01-05-2006, 11:00 PM   #12
http://www.teamlosi.com/jrxs-page/Se...et%20index.htm
Old 01-05-2006, 11:03 PM   #13
That is what I have ran in to also. Work one place but not another. They sound like good base set ups then you need to tweek it from there. Another helpful item I found was the book they include with the Hudy set up boards.
Old 01-05-2006, 11:07 PM   #14
Maybe if you list you car and your basic set up another person who views this thread can give you some input
Old 01-05-2006, 11:07 PM   #15
Moderator
It really sucks because practice is only 20 min. so you can't mess around with much.
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Best Rubber Tires for Carpet? punkracer24 Electric On-Road 5 08-19-2007 11:23 AM
Rubber on Carpet? edseb Electric On-Road 2 05-08-2005 03:43 PM
Rubber tires on carpet? TC3er Electric On-Road 22 03-10-2004 09:06 PM
Best rubber tires for carpet wdm80 Electric On-Road 44 02-20-2004 04:38 PM
