Old 01-05-2006, 11:09 PM   #16
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
Originally Posted by tunnelhead
Maybe if you list you car and your basic set up another person who views this thread can give you some input
I'm running a jrx-s.
roadrashracing is offline   Reply With Quote
Old 01-05-2006, 11:13 PM   #17
try looking around the JRX thread here at rctech. That is why I chose the XRay 05. A handful of guys are running it at most are will to help out. Whats your car doing that you dont like?
tunnelhead is offline   Reply With Quote
Old 01-05-2006, 11:14 PM   #18
Moderator
Front
4 deg caster
Camber link middle hole inside.
Steering stock (no bump shims)
high roll rear block, low roll front block and raised 0.050". 1 deg toe block.
Shocks middle hole on tower, 35 lb spring, 40 wt. oil #60
diff low, mid wheelbase.
Rear
standard 0deg hubs, 2 deg inner toe in.
Camber link middle row-middle hole. Outside on hub and raised 0.030" short ballstud.
Shocks out on arm, three in on tower. 10.5 lb spring 40 wt. oil # 57
diff high, mid wheelbase.
Old 01-05-2006, 11:15 PM   #19
Moderator
I post there a lot. I was turn to get help from more people.
Old 01-05-2006, 11:17 PM   #20
how does this car react with this set up?
Old 01-05-2006, 11:18 PM   #21
Moderator
I started by moving the shocks out 1 hole front and rear, it seemed to help a little, then I broke just before the main.
Old 01-05-2006, 11:19 PM   #22
Moderator
Thats what I started with and it was lose through the hole turn. It kind of hard to try one thing at a time. I am getting some new tires and hopeful it will help a little.
Old 01-05-2006, 11:24 PM   #23
another place to try is www.jrxs.com
Old 01-05-2006, 11:30 PM   #24
Moderator
tried there to.
Old 01-05-2006, 11:42 PM   #25
Anders Myrberg's Avatar
Sorex 28 with JB thin blue or Yellow inserts will give you a lot more grip than "slippery CS 27:s".
Canīt understand why TakeOff CS 27 is so popular. I regard it as a quite bad tyre.
Anders Myrberg is offline   Reply With Quote
Old 01-06-2006, 12:26 AM   #26
AdrianM's Avatar
Traction is bad with CS22's with euro carpets and your limited traction componds. The carpet we race on is higher bite and we have traction compounds that might make you grow a 3rd arm from the center of your chest...lol!
With Paragon or TQ purple on CS27's you can have enough grip to easily traction roll.
Adrian Martinez
Old 01-06-2006, 05:06 AM   #27
Eirik's Avatar
Hello,
Try more rear toe-inn, 3deg is good!!
Spashett had the same problems with his car at last years GP Carpet World Cup and I put 2x1.3mm hole pistons and 60wt oil in all his shocks and that made a HUGE difference on his car!!
His car was right on pace after that, so I suggest you give it a try!!
Eirik is offline   Reply With Quote
Old 01-06-2006, 05:20 AM   #28
try the lrp vtecs very good on carpet and last a long time , i use lrp carpet additve works well enough for me but jack the gripper and cs-racing compounds work better.
Smoking motor.. is offline   Reply With Quote
Old 01-06-2006, 08:45 AM   #29
Send a message via AIM to R/C Anonymous
ill run my JRXS there this next Wednesday and see how my setup does...all i would change is the tires
changing your tires is gonna make a huge difference on that track...when we used to run there a few years ago we never ran CS 27's...we ran Sorex 28 with HPI red inserts all around or Sorex 28 with HPI red insert in the front and Sorex 24 with HPI red insert in the back
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-06-2006, 10:18 AM   #30
Moderator
do you think anyone in town has them, or is that something I need to order?
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Best Rubber Tires for Carpet? punkracer24 Electric On-Road 5 08-19-2007 11:23 AM
Rubber on Carpet? edseb Electric On-Road 2 05-08-2005 03:43 PM
Rubber tires on carpet? TC3er Electric On-Road 22 03-10-2004 09:06 PM
Best rubber tires for carpet wdm80 Electric On-Road 44 02-20-2004 04:38 PM
