pitbull x3 help
Old 01-04-2006, 11:36 PM
nikkiesteban's Avatar
Default pitbull x3 help
just bought PX3 charger... and i wanna ask you guys, what is the best settings for GP 3300mah and Yokomo 3300mah... tnx guys... and im kindly requesting for some explanations of features in this charger.. i cant understand the manual... tnx guys..
is this charger good???
nikkiesteban is offline
Old 01-05-2006, 12:09 AM
the Pitbull X3 is a very good charger,for 3300's I would go with 6 amps at a .03 peak detect.
Hyper1 is offline
Old 01-05-2006, 02:58 AM
ok tnx.. but can be very specific.. coz i really can't understand all.. what is .012volts peak detect?? can u give the value of it..
or please guide me in charging my GP 3300mah batts...
amps=
peak detect=
triple rate=
etc.........
i really dont know how to use this charger coz its new to me.. hope some1 helps me..
Old 01-05-2006, 03:17 AM
Thumbs up
the peak detect goes in increments like this .012, .016, .020, .024... etc
for gp3300 i found peak detect .020 is a good starting point (maybe goto .024 if it is not hot enough when it peaks)
amps = 6.0
trickle = no
Lockout = Y , 2750mah. (you need to set Y on each new charge as it defaults back to N after every charge, also only use a high lockout like 2750 if you have a fully discharged pack, otherwise put the lockout to around 1000mah)
XingXing is offline
Old 01-05-2006, 03:51 AM
XrayFK's Avatar
amps=
peak detect=
triple rate=
etc.........
If you want to use the triple stage charging, these are the steps (in order they appear on charger):
Peak Detect .032
mahr Lockout 2550 Y
Trickle Charge N
Charge mode Triple Rate
Stage 1 2400 mahr 7.00 Amps
Stage 2 100 mahr .70 Amps
Final Stage 6.00 Amps
You can try different ways of triple stage charging, but I have found this to be a good starting point for GP3300s.
XrayFK is offline
Old 01-05-2006, 04:12 AM
thank you guys... any other setting are appreciated here.. so if you have any settings kindly input it here..
what is much better triple rate charge or not..
Old 01-05-2006, 12:41 PM
XrayFK's Avatar
Different people will give you different answers, but I feel that triple rate charging gives you a bit more in stock and 19T, don't know about mod. If not, just go with a 6A linear charge.
Back to the triple charge, the first stage is designed for punch, hence the high rate, then the second "slow" step is to let the battery cool and reduce some IR, then the last is for runtime. From the setup I gave, you can try lowering the last step to 4.5A for more runtime.
XrayFK is offline
Old 01-05-2006, 07:58 PM
the only one that only confusing me now is the peak detect....
is different from other chargers that i have..
in my quasar pro it has a detect peak of 3mv etc...
in my pitbull x3 it has .012 etc....
or the pitbull x3 corresponds its value to other charger like .012 correspondes to 3mv... something like that.. if it has a corresponding value to other charger can some1 please list down the .012 up to its maximum peak detect, that corresponds to other charger.
tnx..
Old 01-06-2006, 05:05 AM
XrayFK's Avatar
tnx..
The peak detect on the X3 is for the entire pack. So 3mv/cell equals .018v for the entire pack.
XrayFK is offline
Old 01-06-2006, 05:38 AM
how about 5mv/cell???
can u list down the equivalent or pitbull peak detection to something like
.018 = 3mv/cell
etc = etc
tnx.
Old 01-06-2006, 06:35 AM
all you gotta do is mulitply the per cell # by the # of cells.
Hyper1 is offline
Old 01-06-2006, 02:58 PM
can u kindly explain more.. i can't get it.. sorry.. tnx..
Old 01-06-2006, 03:48 PM
cant say it anymore clearer.
XingXing is offline
Old 01-06-2006, 06:07 PM
XrayFK's Avatar
Well, if you use the metric at all, "milli-" equals one one thousandths. So 3mv/cell is .003v/cell. There are 6 cells in a pack so .003 x 6 = .018v for the whole pack.
1mv/cell = .006v for the pack
2mv/cell = .012v for the pack
3mv/cell = .018v for the pack
4mv/cell = .024v for the pack
5mv/cell = .030v for the pack
and so on...
Clear?
XrayFK is offline
Old 01-06-2006, 06:31 PM
and so on...
Clear?
tnx alot bro... im happy now..
just one more.. i cant remove the sound when im in charge mode setup? why is this.. but in text audio i turn all into 0... and then it says saving settings..
