Old 01-06-2006, 07:41 PM   #16
XrayFK's Avatar
Originally Posted by nikkiesteban
tnx alot bro... im happy now..
just one more.. i cant remove the sound when im in charge mode setup? why is this.. but in text audio i turn all into 0... and then it says saving settings..
If you're talking about the beeps it makes when you change a certain charge setting, then sorry, you can't remove all the sounds.
XrayFK is offline   Reply With Quote
Old 01-06-2006, 07:52 PM   #17
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
yes that's what im talking about!!! grrrrr.. it's very annoying!
it makes me freaked!! tnx anyways....
i wanna ask something.. for example if my power supply is only 3amps.. and i set the x3 to charge at 6amps.. will my charger break?? or is there some parts on x3 that can be broke? or it can only give 3amps bcoz of the amps??
nikkiesteban is offline   Reply With Quote
Old 01-06-2006, 10:22 PM   #18
XrayFK's Avatar
DO NOT try to charge at 6A with a 3A power supply. I suggest getting a nice power supply, it will last you for many years. The best power supply by far for your money is the Pyramid PSV200, buyreliant.com has them 55 bucks.
Old 01-07-2006, 02:47 AM   #19
how about if im gonna charge my 1700mah POWERS battery... what will be the settings.??? tnx
and what will be the settings for my 1200mah intellect rx batts..? tnx
Old 01-07-2006, 05:13 AM   #20
XrayFK's Avatar
1700 cells? Dang, well I guess I would say charge around 4.5-5A with a cutoff around .042v. As for the AA batteries, the best would be to get a AA charger that charges the batteries individually. If not, charge them at no more than 1.2A, and use a cutoff of .036v
Old 01-07-2006, 05:33 AM   #21
when i charged my 1200 intellect rx batss... the charger says ""argggg lo amps"""" why is that???
Old 01-07-2006, 05:33 AM   #22
when i charged my 1200 intellect rx batss... the charger says ""argggg lo amps"""" why is that??? do u think it can handle rx batts?
Old 01-07-2006, 06:15 AM   #23
check your leads, also when charging do not move your leads, it creates resistance.
qwerty is offline   Reply With Quote
Old 01-07-2006, 10:42 PM   #24
sup
sup's Avatar
it can handle rx packs. my guess is, your rx batt is not used for a long time and left with no charge. it might be dead. try charging at low amps first then discharge and continue till it charges at higher amps. if not, it is definitely dead.
sup is offline   Reply With Quote
Old 01-28-2006, 06:44 AM   #25
what if im charging NICD into my PitbullX3, is there a settings that i should change?? like settings for NICD or NIMH.
Old 02-03-2006, 02:40 PM   #26
charge suggestions for ib3800 please?
racerfreedxxxs is offline   Reply With Quote
Old 02-03-2006, 02:52 PM   #27
nope
XingXing is offline   Reply With Quote
Old 02-03-2006, 03:21 PM   #28
long lockout for 3000, volt peak for .28,, off the trickle, 4-5.5 amps charging.
Old 02-04-2006, 01:32 AM   #29
XrayFK's Avatar
It depends what kind of cells, but Nicd cells will need a higher peak detection compared to Nimh.
Old 02-04-2006, 01:37 AM   #30
XrayFK's Avatar
6A linear charge .024v peak detect, unless you're charging in hot conditions, then lower the peak detect one setting. Basically you want the cells to finish charging at around 120-130 degrees.
If you want to try step charging:
7A for the first 3050mah
0.66A for the second 100mah (only qualm I have is that you can't go lower than 100mah)
5.5A for final stage.
**Note, you must enable the long lockout every time you step charge so it doesn't false peak, set it to the sum of the first and second stage, so in this case 3150mah.
Again if it's hotter, than charge at 6.0-6.5A for the first stage. If you need more punch, raise the final stage (stock) but you can lower it to 4.0-4.5A for mod. This should be a good starting point, but feel free to experiment and find what works best for you.
Pitbull X3 Brian Anthony R/C Items: For Sale/Trade 9 08-13-2007 12:00 PM
Pitbull X3 Brian Anthony R/C Items: For Sale/Trade 0 03-04-2007 04:29 PM
Pitbull X3 and 20 amp PS JJ187RC R/C Items: For Sale/Trade 11 05-05-2006 01:18 PM
pitbull x3 help nikkiesteban Electric On-Road 3 12-27-2005 07:12 AM
CE PitBull Diva R/C Items: For Sale/Trade 2 01-18-2004 04:40 PM
