Vbc D09
#241
I found one setup sheet at the very beginning of the thread. It is for a car with the carbon chassis. Does anyone have a setup to share for a car with the aluminum chassis? I'm running USGT on black carpet, large sweeping track. TIA
#242
Here's one that you could try:
VBC Racing WildFire D09 - Gary Lanzer - WCIC - Sakatoon - 29-09/01/10.2017
It's for a 17.5 but it should get you close.
#243
#244
A few questions about D09 parts if anyone can help. Suspension parts come as: V2, V3, Red, Gold, Silver, V3 D07 HD, Version 2 Composite, and Composite X. I'm planning on going Composite X high carbon red on everything except the steering blocks and uprights which will be Composite X silver.
Is there a breakdown of what all of the different offerings are and does my plan sound like a move in the right direction?
Finally, can anyone tell me the thickness of the zero offset hex wheel hubs? My kit came with the -0.5 4.5mm hexes. I'm looking for a way to narrow the rear with thinner hubs if they are available. TIA
#245
Is there any solution to these garbage wobbling diff housings?
High side.
Low side.
High side.
Low side.
#246
A better shot. Story is that the diff that came with the kit I bought is wobbly. I bought a new replacement from TQ that has the exact same problem!
#247
Vbc released new differentials that address this issue. I purchased two of them but have not assembled them yet.
#248
#249
Yeah, new pn. It is a new design. Larger shafts on the outdrives, larger bores in the housing.
https://www.vbcracing.com/products/p...t2-t3-t4-d0312
#250
#251
Thanks again. Having just bought a replacement diff case from TQ, I wrote them to see what they would do to resolve the issue. I'm hoping that VBC will offer to send one of the new diff kits to purchase in lieu of the old diff.
#253
Here's the fix. Part Number - D0312
From VBC: "This new gear differential set with new wide gear shaft technology proven to minimise centre misalignment and wobbling during high revs. The new gear diff housing shaft and bearing slots are individually precision CNC machined to provide minimal tolerance. The housing, internal gears and internal gear shaft are made with carbon injected CompositeX compound which provide lightweight, long lasting and rigidity. This gear diff set is compatible with all VBC WildFire series TC, Ghost series TC, FF18 TC as well as Xray T2/T3/T4 cars."
#254
This chassis is amazing. Wow.
#255
