Old 01-04-2006, 05:07 PM   #1
nexxus's Avatar
Trader Rating: 302 (100%+)
Default Steering problems on Tamiya TA05 and M03L
I have a TA05 and a M03L and both have the same steering problem where on one side they don't centre back properly, it looks to be a problem with the standard Tamiya Servo Saver but not 100% sure, any ideas and how do I fix this?? Has anyone else noticed the same?
nexxus is offline   Reply With Quote
Old 01-04-2006, 05:09 PM   #2
newracer's Avatar
R/C Tech Charter Subscriber
Get a Tamiya heavy duty servo saver or Kimbrough
newracer is offline   Reply With Quote
Old 01-04-2006, 05:15 PM   #3
nexxus's Avatar
Will that fix it?
Old 01-04-2006, 05:34 PM   #4
Ghostfit's Avatar
Try lubricating the servo saver parts with some light (preferably dry) lubricant.
.....and make sure you did not over tighten the screw securing the saver to the servo.
.....lastly, make sure all steering components has NO binding anywhere !
Ghostfit is offline   Reply With Quote
Old 01-04-2006, 06:16 PM   #5
academygaz's Avatar
My M03 had the same problem, I cured it with a zip-tie around the centre plastic ring. The problem was the ring was weak and didn't tighten up enough to return to centre.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 01-04-2006, 06:24 PM   #6
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Are you useing the same exact servo on both cars? What I mean is do you change the back anfd forth from car to car?
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-04-2006, 06:46 PM   #7
nexxus's Avatar
No the TA05 has a Futaba 3305 the M03L has a Futaba 9451
Old 01-04-2006, 06:50 PM   #8
dodo's Avatar
Send a message via Yahoo to dodo
i am not sure but in my opinion this will make your servo saver 'dead' or in other word, you're not using any servo saver. when you zip-tied it, the center ring can't expand and provide the 'spring' action which is supposed to be there so it can act as servo-saver.
dodo is offline   Reply With Quote
Old 01-04-2006, 06:57 PM   #9
dodo's Avatar
i have not tried kimbrough ones but i tried the one from eagle racing, it can't fit because it hits the tub chassis sidewall.
tried the tamiya one, fits better but still have clearance issue, the ball cup hits the servo casing whenever i turn to the right, well it still clears but scrubbing the servo casing. any suggestion on how to fix this?
oh btw i'm using futaba 9550 servo
Old 01-05-2006, 01:37 PM   #10
newracer's Avatar
Will that fix it?
This
and/or this
will fix it.
Old 01-05-2006, 06:44 PM   #11
Ghostfit's Avatar
Might as well CA (Super glue) the whole servo saver together !
Old 01-05-2006, 07:00 PM   #12
snopro31's Avatar
Trader Rating: 36 (100%+)
The Tamiya high torque servo saver works well .
snopro31 is offline   Reply With Quote
Old 01-05-2006, 07:02 PM   #13
Regional Moderator
Darkseid's Avatar
Get yourself one of these
http://www2.towerhobbies.com/cgi-bin...&I=LXND49&P=ML
and forget about the Tamiya one all together.
I know it will fit the TA05 cause I use one on mine.
TLR 22...Tamiya F104...
Old 01-05-2006, 08:11 PM   #14
nexxus's Avatar
Thanks going to buy a Kimbrough and a Tamiya one and see which helps the most, also backed the servo screw off a tad and thats helped it a bit as well.
Old 01-05-2006, 08:51 PM   #15
tomdav's Avatar
Trader Rating: 42 (100%+)
Default saver
The tamiya ones gave me nothing but fits. The metal rings have play where the ends meet the plastic. People jam stuff in there to take up the slack but I would just avoid it and get the med. kimb.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Tamiya M03L for sale g-vwow Australia For Sale/Trade 1 06-08-2007 01:27 AM
Tamiya BMW Z3 M03L NIB needrcspeed R/C Items: For Sale/Trade 4 11-24-2006 03:24 AM
EOI - Tamiya Mini M03L fleagun Australia For Sale/Trade 1 08-17-2006 06:39 PM
Tamiya Mini M03L Takt R/C Items: Wanted to Buy 2 06-16-2006 03:54 AM
Tamiya M03L for sale Vinyard R/C Items: For Sale/Trade 0 12-23-2003 11:39 AM
