Opinons on the Novak Smart Tray.........
I would like to here some opinons on the Novak Smart Tray. Is it really worth the money?
RH
RH
Works good for me, a lot of people seem to like them.
I've had it almost six months and use it all the time. Love it.
Tekin discharges down to .5 volts per cell and holds them there. Cells seem to work best when left on overnight.
Novak has a programable cutoff per cell from .1 to .9 but does not hold the voltage at the cutoff. Good for equalizing just prior to charging.
Novak works much faster than the Tekin. Really depends on what type of cells you use.
Registered User
two words....
A- MAZING
A- MAZING
Originally Posted by XrayFK
Wait, so the Novak doesn't hold the cells at the cutoff voltage? I thought it would keep cells that are done at 0.9v until the rest of cells are at 0.9v as well. can someone clear this up please?
The Smart Tray does get them down to .9 volts per cell but then once it does, it shuts off. But the cells do rejuvenate, so after a while they are not necessarily at .9 anymore. There are other trays that hold them at the specified voltage, I believe the battery doctor is one of them.
But - having said all that... I still bought a Novak Smart Tray because of all the good things I've heard about it. You can always just retray them or hit the button again after they sit there for a while.
Originally Posted by c-lyon
Don't forget you can take the Novak down to as low as .1.
