Old 01-04-2006, 05:50 AM   #1
Default how to prevent charger from arcing?
hi, when i connect charger to the PS it makes a spark (called arcing?) and it makes my PS switch off, So basically i need to turn off my PS before connecting a charger, which sometimes is not practical.
is there anything i can do to prevent the arcing caused by the charger when connecting it?
XingXing is offline   Reply With Quote
Old 01-04-2006, 06:08 AM   #2
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
maybe your PS is low on amps to your chargers need... try more other PS that has higher amps.. BTW what is your PS amps?
nikkiesteban is offline   Reply With Quote
Old 01-04-2006, 06:14 AM   #3
25amp computer ps
Old 01-04-2006, 06:28 AM   #4
ChrisP's Avatar
25amp computer ps
I installed the Sermos (black and red lego block style) connectors on to my chargers PS cable, and on the power supply I instaled a couple pieces of wire with those connectors...
no arcing when you plug in, and it also protects against hooking the charger up backwards(reverse polarity)
You can still use the clips by installing the mating plugs onto the clip section of the charger's power cable that you cut earlier...
It works nice!
ChrisP is offline   Reply With Quote
Old 01-04-2006, 06:30 AM   #5
BadSign's Avatar
Trader Rating: 15 (100%+)
If you haven't modified your PS at all, it will need capacitors installed. Look around here or on Hobbytalk, maybe even rc-oval.com for conversion instructions.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 01-04-2006, 06:34 AM   #6
hi, how are those sermo plugs different to say bannana plugs? i tried bananna plugs and they still arc.
Old 01-04-2006, 07:11 AM   #7
ChrisP's Avatar
you're plugging both in at the same time....vs. separately with banana plugs
Old 01-04-2006, 08:27 AM   #8
Send a message via AIM to rcguy2477
Computer power supplies are created to operate on a constant load. When a large load is put on(ie. connecting a charger), it causes current spike, which will in turn turn off the power supply.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 01-04-2006, 08:33 AM   #9
ChrisP's Avatar
which explains the earlier posters comments about adding a capacitor...
Actually, in just about any PS, they recommend to power it off before connecting to it anyway...
Old 01-04-2006, 02:20 PM   #10
XrayFK's Avatar
Try turning the ps on after you have the charger plugged into it.
XrayFK is offline   Reply With Quote
Old 01-04-2006, 10:37 PM   #11
asw7576's Avatar
25amp computer ps
Computer ATX PSU have built in protection against sudden voltage drop / over current / spikes. It will shut down in split second to protect the systems.
So plug in your stuffs before turn it on.
Old 01-05-2006, 02:42 AM   #12
I also understand the need for "plugging stuff in" before turning on the PS, but what if there were something already plugged in the PS (say, another charger?).
Alfalfameister is offline   Reply With Quote
Old 01-05-2006, 04:22 AM   #13
XrayFK's Avatar
Then you have to wait, or keep everything plugged in from the start.
Old 01-05-2006, 08:08 AM   #14
Scrubb's Avatar
intresting, since plugging in the charger causes the power supply to shut off anyway, it wouldn't seem very impractical to turn off the power supply first to begin with. Really, either way the power supply is going to get turned off.
I'm glad I bought a hobby grade power supply designed for the application from the start so I didn't have to deal with such a ridiculous self created problem.
Scrubb is offline   Reply With Quote
how to prevent fraud. pinggoy Chat Lounge 14 09-06-2006 09:01 PM
Arcing/Glitching Problem 4x4xfar Monster Trucks 22 09-26-2005 07:56 AM
Way to prevent damage??? Greenbox Onroad Nitro Engine Zone 7 08-11-2005 08:29 PM
Arcing in electric bvoltz Rookie Zone 5 07-30-2005 09:24 PM
arcing in motor nitro2electric Electric On-Road 5 09-06-2004 02:23 AM
