Old 01-04-2006, 12:02 AM   #1
Default how to wire a switch...?
hi i got a switch, its got a light on it... it has 3 terminals,
Two are small and one in the center is taller
How do i go about wiring it up?
XingXing is offline   Reply With Quote
Old 01-04-2006, 12:04 AM   #2
Suspended
Trader Rating: 14 (100%+)
One to the middle, one to either side.
Phatkat is offline   Reply With Quote
Old 01-04-2006, 12:10 AM   #3
so black in the middle and red to either side?
Old 01-04-2006, 01:12 AM   #4
Suspended
Sorry, shoulda been clearer. I meant one on only one side. You only need two, and it will only work in one position. If I remember right, that is a DPST switch, or double pole single throw.
Old 01-04-2006, 01:39 AM   #5
i do this, it works in one direction, but when i flick the switch it shorts....
Black is in the middle , red is on on of the side
Old 01-04-2006, 01:52 AM   #6
Suspended
You're completing a circuit with that, and have no load. What is that anyway?
Old 01-04-2006, 01:59 AM   #7
12v distribution block with 4 outlets... with the one switch controlling all 4 outlets
Old 01-04-2006, 02:02 AM   #8
ford_racing's Avatar
Send a message via MSN to ford_racing
This switch has to be in either the 12v pos or 12v neg wire, not both as it will short out
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 01-04-2006, 02:29 AM   #9
like this? red split in between and the black on the middle terminal
the switch is a on/off switch with a light on it.....
Old 01-04-2006, 02:37 AM   #10
pyrosian's Avatar
The positive wire should go from the power supply to one pole of the switch, then continue on to the jacks.
Positive -------- switch -----O----O----O----O
Negative --------------------O----O----O----O
The switch controls power to the entire circuit. The device that you plug into the jacks complete the circuit. As you havre it at the moment when you flick the switch you are connecting positive directly to negative with no load on the circuit which will equal a dead short. With the above circuit when no device is plugged in and the switch is on the circuit is still open and won't short out.
pyrosian is offline   Reply With Quote
Old 01-04-2006, 02:59 AM   #11
ok i do this, it seems to work...
Positive --- middle terminal switch ---- space ---outer terminal on switch ---O--O--O--O
Negative -----------O----O----O----O
but it doesnt give me 13.8v ... only puts out 11volts
Old 01-04-2006, 03:50 AM   #12
pyrosian's Avatar
Yep thats exactly right. As far as output goes 11v should be enough for most things. Check your output on the powersupply if that is 13.8V it simply means there is alot of resistance in the wiring. Shorter wires, neat and quick solder joints and using higher quality connectors would/should lower resistance.
Old 01-04-2006, 03:56 AM   #13
there must be a heck of alot of resistance between the switch, coz when i directly hook it up to the 4 terminals, it still gives me the 13v that my PS gives out,
the 11v wont even run a fan. when i put a fan the voltage drops to 2.8v on my multimeter.
Old 01-04-2006, 04:07 AM   #14
pyrosian's Avatar
11V should easily turn over a fan. I have run 12V fans straight off my 7.2V packs before and they run fine. If you did accidently short out the box earlier you may have damaged your powersupply. If you have access to a DC clamp type multimeter you may want to test how many amps that unit is throwing out.
Old 01-04-2006, 04:33 AM   #15
PS is still ok. i power my charger and fan direct from my PS works fine.
Not sure why the voltage on the distributor block drops to 2v when i connect a fan (fan does not even spin)
oh well i give up on the switch now.
GTX 16 g wire ?? gurumods Electric On-Road 5 02-27-2007 09:10 AM
when not using a switch how do run your battery wire setup ? mrgsr Nitro On-Road 9 04-25-2006 10:49 AM
Fet wire on GTX? Tony Szep Electric On-Road 2 04-24-2005 06:22 PM
FS: GM V3r 4-wire ESC rodneybarrett R/C Items: For Sale/Trade 0 09-28-2004 09:47 PM
Anyone know where to buy "26 Awg, 22 Stranded Wire" or typical antenna wire? Thanks Shrub Electric On-Road 9 04-16-2004 05:57 PM
